Re: Need ideas for a 450HP build on my 383/ street motor?
[Re: RUMBLON]
#975519
04/20/11 01:12 PM
04/20/11 01:12 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
That changes everything. Use the 500. The compression is perfect for an aluminum head street engine. You need to find out what cam is in it. It may be OK to use. What manifold is on it? Chances are it is OK also. The rockers will be OK as long as they are not some inexpensive Chinese junk. If they are then they wouldn't have held up in a race motor either. As far as the pushrods go, he probably wants to check the length with what ever cam would be put in.
IMO you already have the right engine sitting there ready to use unless the cam is way too big.
Should be way past your Horsepower goal even with a mild street cam.
[Re: GomangoCuda]
#975520
04/20/11 02:28 PM
04/20/11 02:28 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
OK here are a few pics.I dont think the rockers are cheap ones but then again, I am not the builder. I do want to use this motor if at all possible if its not going to cost a ton.
RUMBLON
[Re: RUMBLON]
#975525
04/20/11 03:33 PM
04/20/11 03:33 PM
GomangoCuda
Find out what cam is in it. There's your engine. There are more street worthy intakes out there but that one will work for now. Do you have a Carb for it? $200-$250 would get you a more street friendly intake.
Rocker arms look good enough.
[Re: RemCharger]
#975527
04/20/11 08:20 PM
04/20/11 08:20 PM
RUMBLON
Cambridge Idaho
Looks good to me Rockers look like they're of asian descent , but if the cam isn't to heavy duty, should be ok. Is it a roller cam? If its a solid ft, I don't see any problem running it. Check lash a few times , and let er eat.
What would a good cam and intake be for this?
[Re: RUMBLON]
#975528
04/20/11 09:06 PM
04/20/11 09:06 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
I'd run a performer RPM, maybe with the divider ground down and a 2" spacer and if you're looking to stick with flat HYD, maybe go with a hughes HEH3742BL or HEH4246 (237/242 @ .050, .584/.592 lift w/ 1.6 rockers, 108 LSA or the later which is 242/246 @ .050, .592/.606, 108lsa)...that should hopefully keep cylinder pressures down so that you'd be happy with pump gas and still make PLENTY of power. The amount of low/mid range torque w/ either cam would be stupefying though. Nor would I be adverse to doing a basic 383...with a good "268" cam and tri-y headers with good AL heads it'd be a nice street combo that would certainly be enjoyable at a cruise night and smile inducing at a stoplight drag
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
[Re: RUMBLON]
#975529
04/20/11 09:06 PM
04/20/11 09:06 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
You have to choose intakes wisely as hood clearance can become an issue.
[Re: JohnRR]
#975531
04/20/11 11:26 PM
04/20/11 11:26 PM
RUMBLON
Cambridge Idaho
Run a performer RPM , find out what cam is in there and ask the builder about the rockers, if they are (insert board sponsor here) or CAT rockers TAKE THEM OFF NOW AND THROW THEM AWAY .
I called my builder. Its been a long time but he said he does not buy cheap rockers. Also I think I screwed this up, the cam is a big roller cam. I think I said solid before. He also feels that we can change the cam, lifters,springs,and manifold and be good.
[Re: Cab_Burge]
#975533
04/21/11 11:28 AM
04/21/11 11:28 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
with 500+ inches, the single plane will probably be OK on a street car....
for a cam, I'd talk to tim at bullet cams and have them grind one. you could stick with a solid roller, since you already have the expensive part (lifters), and just get one with semi-mild ramps, probably [Email]250-260@.050[/Email] duration, and ~.4-.42" of lobe lift, maybe something like their R294/415 on the intake?
and it will make way more than 450hp....
[Re: Cab_Burge]
#975534
04/21/11 01:36 PM
04/21/11 01:36 PM
RUMBLON
Cambridge Idaho
Those look like a set of T&D rockers Good stuff That intake works well on big motors also Its ready to run, check the cam for duration and lift and see if you want to try it before "fixing it"
Cab thanks. This builder is the same guy who built that 572 Indy Maxx motor a few years back. Hes a good builder so I didnt think he would throw any junk on it for lifters. But I also like to get opinions from mopar folks on here as hes a builder of all brands since the 60s. Would you keep the roller cam or go with a solid roller cam.This is going to be driven a lot and have after market A.C. Power steering and power brakes.
RUMBLON
[Re: RUMBLON]
#975535
04/21/11 01:42 PM
04/21/11 01:42 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
RUMBLON
I like big cams in stroker street motors, especially solid roller cams There are draw backs like roller life when compared to the hydraulic roller lifters in the same motor. Find out the specs on the cam and let us know or PM me for future suggestions, no sense in getting into a discussion on cam lobes with everybody and there brothers on here I will need to know more about the car also like converter size and brand, rear gear ratio, car weight and some other things
[Re: Prince_Valiant]
#975536
04/22/11 02:57 PM
04/22/11 02:57 PM
RUMBLON
Cambridge Idaho
Thanks for the part numbers. I think I am on the right track. This sure beats letting a race motor sit and building a whole new engine.
And Cal, the builder says he thinks your right on the rockers, thats a typical rocker he uses.
[Re: RUMBLON]
#975538
05/07/11 11:33 PM
05/07/11 11:33 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
As a final thought on a 450 hp 383 big block, check this article out: "383 Power Play" by Steve Dulcich, in Engine Masters, Spring 2009. Well thought out and done mostly with production pieces that passed inspection. Simple, EFFECTIVE bolt-ons that yielded GOOD power!! Good tech, Steve!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
