Re: super low budget 318
[Re: moturbopar]
#975424
04/18/11 02:35 AM
04/18/11 02:35 AM
Posts: 301 California
court9155
California
Did someone give you a 30 over block cuz around here 200 wont even get it boiled and bored
67 charger
[Re: moturbopar]
#975426
04/18/11 06:25 AM
04/18/11 06:25 AM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
The carb seems a little big for the cam, cubes and stall. I'd try a swapmeet 600 Holley since they're cheap to find. Switch back to the 750 when you do track time with the nitrous.
Do you have the valvesprings to compliment the cam?
Is that a calculated compression? How much is the piston in the hole?
[Re: Dean_Kuzluzski]
#975428
04/18/11 01:43 PM
04/18/11 01:43 PM
Posts: 164 mesa arizona
moturbopar
mesa arizona
Im not too worried about the carb, the engine wont really be in too long. when I put the 360 in I will probably give the 318 to my son, for a project when he is ready to drive. The 750 will go on the 360.
The valve springs are comp 901s The compression is calculated piston sits around .017 in the hole gasket is 4.1 bore and is thin compresses to .038 releifs in piston 4cc heads measure out to 70cc
[Re: rustbuckett68]
#975430
04/18/11 04:22 PM
04/18/11 04:22 PM
moturbopar
mesa arizona
He must shop where Horsepower TV does. Remember the 360 c/w Eddy heads, intake, roller cam, Holley and headers for what $475.00. They put it together without even changing the rings.
Ha! I wish, been collecting these parts for 8 years!!!!thats befor I even had a mopar!
[Re: moturbopar]
#975431
04/18/11 08:48 PM
04/18/11 08:48 PM
750 Holley 3310 is perfect for that motor IMO.
With a very similar combo I was running 14's @ 95 mph with no traction and 3.23 gears.
My compression was lower and the car weighed 3,400.
Mine was low budget as well.
A very fun motor that I wish I still had!
[Re: moturbopar]
#975434
04/21/11 09:57 AM
04/21/11 09:57 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Got the car fired up and cam broken in, sounds pretty good. Cam sounds small, but the car has a ton of throttle response. I cant wait to drive it! Just need to finish the brakes up, and hang the tail pipes.
ahh who needs brakes, they just slow ya down.
