Re: Recommendations on Carb Restoration
[Re: MMC Detroit]
#975034
04/18/11 09:00 AM
04/18/11 09:00 AM
Well, with what I went through with my AVS with Dick, I think I will be sending it to Scott the next time it needs to be redone!
[Re: ]
#975035
04/18/11 09:17 AM
04/18/11 09:17 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Scott: It'll cost you but you know what you will get.
AAR cuda
71 rag challenger
[Re: 3406pac]
#975036
04/18/11 09:20 AM
04/18/11 09:20 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
after 35 years of sitting.
AAR cuda
71 rag challenger
[Re: 3406pac]
#975037
04/18/11 09:24 AM
04/18/11 09:24 AM
Posts: 74,937 U.S.S.A.
JohnRR
U.S.S.A.
I think you have your pictures mislabeled , or Scott is real good at making them look like they were pulled from a swamp .
[Re: JohnRR]
#975038
04/18/11 09:53 AM
04/18/11 09:53 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Hello, Thanks to all of your supportive comments, I appreciate them and your business! *John, I don't know if your were serious or not but in case you were, I photograph all carbs I receive right after I unbox them (in detail including part#'s and date codes) before I begin any work, the photos shown are of the same set of carbs "before & after". Nothing was done to enhance either photo.
[Re: ScottSmith_Harms]
#975041
04/18/11 11:08 AM
04/18/11 11:08 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Scott, do you test run the carbs?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: JohnRR]
#975042
04/18/11 11:35 AM
04/18/11 11:35 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Well maybe I should have added "PRESTO" after 35 years..... This is what you get.
Someday they will make it on the car.
Maybe we need a PRESTO GRAEMLIN
AAR cuda
71 rag challenger
[Re: ]
#975044
04/18/11 01:14 PM
04/18/11 01:14 PM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
Same here! Don't waste your time or money with anyone else.
Scott, you have 3 carbs on the way from me today, just so ya know.
[Re: 3406pac]
#975047
04/18/11 02:29 PM
04/18/11 02:29 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
I can see the surface of the carbs even though dicromate? plated it looks to have a texture from sandblasting....
...is it possible to have a smoother finish as original?
Maybe the pic is deceiving...I dont know.
