Page 3 of 3 1 2 3
Re: oil pump not priming [Re: 471Magnum] #974477
06/03/11 01:59 PM
06/03/11 01:59 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Turned out my pump was quite seated into the pilot hole. Priming shaft wouldn't drop into the drive.
Dropped the pan and reinstalled the pump. Problem solved.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: oil pump not priming [Re: 471Magnum] #974478
06/03/11 02:02 PM
06/03/11 02:02 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Oh for Pete's sake! Good you got it covered.
Page 3 of 3 1 2 3
