8.25 rear axle ? #974361
04/16/11 01:33 PM
04/16/11 01:33 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Can a 8.25 hold up under a stock 440 or is that a broken axle waiting to happen? Trying to figure my options
Re: 8.25 rear axle ? [Re: '84 D150 Shorty] #974362
04/16/11 02:10 PM
04/16/11 02:10 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I say yes it can if the car (truck?) is driven reasonably. The rear doesn't know if the applied torque is from a 318 or a 440---until the torque is MORE than a stock small block would produce.
Lots of hard acceleration or heavy towing and the 8.25 is probably gonna give up after awhile.
One key point would be not to accelerate hard in turns--the spiders/side gears are at work when 'differentiating' and they can't take the power that the ring and pinion can.
Re: 8.25 rear axle ? [Re: '84 D150 Shorty] #974363
04/16/11 02:22 PM
04/16/11 02:22 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
it's always a matter of power/torque of the engine and the wt of the vehicle. I've known a 8.25 lose it's spider gears behind a stock 318 tbi in a Ramcharger...and I've abused the living heck out of a suregripped 8.25 behind a hot 360 in a valiant...and it lived just fine.
I say go with it...if it breaks, upgrade then
Re: 8.25 rear axle ? [Re: Prince_Valiant] #974364
04/16/11 02:26 PM
04/16/11 02:26 PM
IA
landon1 Offline
landon1  Offline
IA
the 440 swap in my satellite was done way before my time, but i've had the car for 8 years now and i've had no problems with the rear axle...and i'm not real nice to it either
'71 Satellite Sebring 440
Re: 8.25 rear axle ? [Re: landon1] #974365
04/16/11 02:34 PM
04/16/11 02:34 PM
TN
Pickup Man
Pickup Man
TN
Cool, thanks guys. I will probably just keep the 8.25 untill something breaks then, lol. I am gonna do the ZJ Grand Cherokee disc brake upgrade on it then, and I can reuse those parts on the 8.75 should the 8.25 break.
Re: 8.25 rear axle ? [Re: '84 D150 Shorty] #974366
04/16/11 03:26 PM
04/16/11 03:26 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I would add ....depends on the gear ratio. LOTS of HOESpower and a short gear ..... you might get into trouble.
Re: 8.25 rear axle ? [Re: dOc !] #974367
04/16/11 06:44 PM
04/16/11 06:44 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Mine likes to spider crack the adjusters even on street tires. Twice I've had to replace them. I would start working on plan "B" & run the 8 1/4" till it grenades.
Re: 8.25 rear axle ? [Re: 80fbody] #974368
04/16/11 08:07 PM
04/16/11 08:07 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Have one in my 69 B'cuda with a 470" BB.3:73 gear 4spd. Seems to hold up OK in my street car....I WON'T put slicks on it though!!
Re: 8.25 rear axle ? [Re: Dcuda69] #974369
04/16/11 11:14 PM
04/16/11 11:14 PM
scratchnfotraction Offline
just think of the axle snapping,then wheel with axle comeing out,then the side of the bed and wheelwell that is perfect with fresh paint and all the work it took to get it that way!.....just before you launch it every time and you will baby that thing till you have plan "B" built to bullet proof specs...then stress test it
there is a reason they made a 10 bolt,12 bolt,8 3/4,D-60
