4-speed guys---best clutch for high hp street car??? #97336
07/30/08 08:12 PM
07/30/08 08:12 PM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
My cuda is done, so it's time to work on the wagon. The engine is my procharged lowdeck, cnc e-heads, hyd roller cam, ect. I just picked up a hemi 18 spline 4-speed to put behind this. I'll be running a 69 11 inch bellhousing and flywheel. This is mainly a street sleeper, dog dish steel wheels, street tires and such. What's the best clutch package to hold this? I really don't think I'll need the dual disc, since it's not going to see slicks.
Re: 4-speed guys---best clutch for high hp street car?? [Re: todd440] #97337
07/30/08 08:51 PM
07/30/08 08:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That 12" unit that Mcleod makes will work well.You can get all the parts from Jamie at Passon Performance.
Gus
64 Plymouth Savoy
Dana 60
Re: 4-speed guys---best clutch for high hp street car??? [Re: todd440] #97338
07/30/08 09:15 PM
07/30/08 09:15 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
No slicks on mine, but I went with McLeod Street Twin anyway. Its good for like 1000hp. At least thats the info I got from the tech at McLeod 8 years ago.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 4-speed guys---best clutch for high hp street car??? [Re: todd440] #97339
07/30/08 09:42 PM
07/30/08 09:42 PM
AndyF Offline
AndyF  Offline
If you have room for the big 143 inch flywheel then get the big 12 inch clutch that Mcleod sells. It is basically a Viper unit that fits a 143 tooth flywheel. It is good for about 600 ft-lbs of torque but it isn't a racing clutch, so no power shifting if you want it to last.
Re: 4-speed guys---best clutch for high hp street car??? [Re: AndyF] #97340
07/31/08 09:18 AM
07/31/08 09:18 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
http://www.brewersperformance.com/proddetail.asp?prod=MCP1118
Give us a call if you have any questions.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: 4-speed guys---best clutch for high hp street car??? [Re: 64dodge572] #97341
07/31/08 06:50 PM
07/31/08 06:50 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
I used a McLeod street twin and a hydraulic throw out bearing setup. No Z bar issues. Nice clutch pedal feel.
