Does this look correct?
Ring Groove size's are 2-5/64 and 1-3/16.
Pin diameter is 1.0939.
Compression Height is: 1.900
I am using the DCC gasket kit which comes with the felpro head gaskets I believe, havent opened it yet but they dont indicate steel head gaskets like factory used.
I am also using 516 heads but they arent on yet not too late to have them decked....
Just opened it up to see what I had.
Its a fresh motor with those pistons, stock valve size 516 (well im assuming havent measured them yet but lookin at them id say stock valve sizing) 474 mopar cam, streetmaster intake and 1 3/4 headers. Im ditching the intake, adding double true roller timing chain and gear, all new gaskets and trickflow head bolts and a windage tray. Like to know ABOUT where my compression is gonna be. Ill know more when I see what the compressed gasket thickness is and see how far down the hole the pistonies are.
Dan
