soldering a radiator
#972936
04/13/11 11:31 PM
04/13/11 11:31 PM
Posts: 4,872 connecticut
pnypwr
connecticut
anyone here ever solder a radiator? I found an aftermarket modine rad with the correct diemensions for my gremlin, it fits an eagle...everythings the same and the pics looked the same also but were diff numbers. well I got it short so im happy but the mounts are on the wrong side...mine mounts to the rear and the new onemounts to the front...so I need to swap the straps. ive sweat pipe but do you need a special solder? which flux? im not a plumber so this is kinda foreign to me...any helps appreciated
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
Re: soldering a radiator
[Re: pnypwr]
#972937
04/13/11 11:43 PM
04/13/11 11:43 PM
RapidRobert
I was gonna say scuff it/clean w acid flux/solder w acid or solid core solder but this Modine unit is alum right? Not sure what to do w that
[Re: pnypwr]
#972939
04/13/11 11:45 PM
04/13/11 11:45 PM
RapidRobert
In that case the above will work
