For give my Ignorance then,thank you.
back on topic..
i have a set of c-body axle that can NOT be cut down to A-body specs,a set of 72 4x4 truck axles that CAN be cut down,but have the 5 on 5.5 wbp.
my 67 polara axles are 30" long and CAN be cut down,but I am told a 67 polara is a c-body.
but dont some of the B-bodys and E-bodys use a 30" axle?
C-bodys and trucks/vans are the best place to find axles that are not tapperd down and could be cut to A-body specs,IMHO the C-bodys are hit and miss
KG just poped a re-splined 8 1/4 axle couple days after doing it,IMHO the 299$ for a set of moser custom alloy axles are worth the $ to do it right the first time.
Doctor diff can set you up for whats needed and a fair price as well
