Re: Voltage drops in a 12v 1954 dodge
[Re: John_Kunkel]
#972445
04/13/11 04:23 PM
04/13/11 04:23 PM
Posts: 55 God's Country PA
Magnus_Jager
God's Country PA
They all worked on 6v before I took it apart. I've since installed a new harness and upgraded to 12v, and they still seem ok. I just don't want a fire in my dash from the resistors on those switches. I have set myself on fire to many times just welding it together.
[Re: Magnus_Jager]
#972448
04/14/11 05:41 PM
04/14/11 05:41 PM
Posts: 1,019 Finland
mafo
Finland
on my 55 I use 56 fan motors and since I couldn't find a 56 wiper motor I made a 90 dakota one to fit, not hard at all I don t think resistors are a good idea, they make a lot of heat if they hold up at all for the gauges I use a small voltage regulator that was also pretty easy to install http://www.eidusa.com/Electronics_Voltage_Regulator.htm
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Magnus_Jager]
#972449
04/14/11 07:41 PM
04/14/11 07:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's probably more of a amperage than voltage issue now. Those reducers, at least the ones I've seen, are designed for light duty loads like gauges. You'd probably be better off with a ballast resistor to be honest but I still think it would reduce the current below the level needed to make the motors work. Will they work if you give them a hand starting?
[Re: Supercuda]
#972450
04/14/11 10:37 PM
04/14/11 10:37 PM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
Just for the record, on 12 volts, my 6 volt fan motor ran much faster then it did on 6 volts, it lived fine until one of the wires shorted out where the old insulation fell off. I replaced the wires to the fan motor and replaced the fan with one from NAPA that fit my heater. The wiper also ran a lot faster on 12 volts then it did on 6 volts. Low speed was about as fast as high speed used to be, high speed on 12 volts was wild. The wiper did not live long on 12 volts, but who knows what condition it was in before I juiced it up? To get a high amp draw 6 volt motor to run on the voltage reducers, you need to have a couple reducers wired in parallel and then 2 in series (4 total) per motor, if I remember right. When I found out I had to buy 4 reducers, I opted to run on 12 volts until they melted down. A ballast resistor does not work either.
The 6 volt started whipped the engine over a lot faster too, made the old engine start easier. As long as you kept the cranking to short crank times, the starter worked fine. If you cranked too long, the starter started to smell funny, didn't seem to hurt it, but I stopped cranking as soon as it started smelling and left it sit a few minutes to cool off. Of course, none of the lights lasted long on 12 volts, and I used a 70s dash reducer for the fuel gauge.
To the guy that used a modern wiper on an older car, I would like to know how you made the wipers work. Did you retain the original wiper pivot positions? I have 1 wiper on my 50 Dodge truck because I can't get the passenger side to move in the other direction from the driver side. The old wipers moved towards each other, and all the new stuff moves with each other in the same direction. Gene
[Re: poorboy]
#972451
04/15/11 04:51 AM
04/15/11 04:51 AM
mafo
Finland
Gene, I used all the old stuff expect the motor itself, the dakota motor was almost a bolt in,you have to make a new sector arm to fit the motor since the original one doesn t fit the new motor, I guess you could modify the old one too..., wiring was a bit tricky if you want to use both speeds
[Re: mafo]
#972452
04/15/11 04:56 AM
04/15/11 04:56 AM
mafo
Finland
you need a dakota wiring diagram to figure it out here is how I did the gauges, they do work on 12 volt but I don t know for how long
[Re: mafo]
#972453
04/15/11 09:30 AM
04/15/11 09:30 AM
Magnus_Jager
God's Country PA
Yeah I built the chip volt drop for the gas gauge, amp meter don't care about volts. My directions had me throw a capacitor in as a sort of surge protector on mine. Oil and Temp are mechanical in this beast. Poorboy I am going to have to send you some beer when this beast is done. You seem to have the info every time. I did have a friend mention using multiples in parallel, but not that might need two in series as well. I currently have 4 or 5 of the bastards, but two different kinds... 2 of these http://www.speedwaymotors.com/Voltage-Reducer-for-Fans-and-Motors,2375.html and 2 or 3 of these http://www.speedwaymotors.com/Electric-12-V-to-6-V-Reducer-for-Motors,15824.html?parentDisplayId=2375 may be worth saving the wiper, as mine also has the reverse action, meaning they both wipe out from the center.
[Re: mafo]
#972454
04/15/11 06:17 PM
04/15/11 06:17 PM
poorboy
Freeport IL USA
Ah, see that's the problem, I'm dealing with wipers on my truck. the original wiper motor had the motor in the center with a transmission on each side to operate each wiper, there is no center arm. My 50, my 54, and my son's 55 all had the dual transmission wiper motors. My 48 Plymouth had a vacuume wiper, but it has the center arm, maybe I can modify the arm and connect it to my Dakota wiper motor. I already have the Dakota wiring harness. That will make life a lot easier. Gene
[Re: Magnus_Jager]
#972455
04/15/11 06:46 PM
04/15/11 06:46 PM
poorboy
Freeport IL USA
2 of these
and 2 or 3 of these
I am happy I may have helped you through the process. I seem to learn everything the hard way, so I figure I should at least offer up some of my experiences to save others from leaning like I did. LOL
My problem is I simply can't remember all the details or the things that would have saved me some heartaches anymore. I seem to remember the real big disasters and some of the things I did to cause them pretty well though.
Does your wiper have a center arm that connects to the links going to each side? If so, you may be able to adapt that center piece to a 12 volt wiper motor. Trucks have separate sides of the motor running each wiper, but cars may be different, I know the 60s cars had a center arm, but don't know when they started with it. There are companies that make wipers that work on these old cars & trucks, but I'm too cheap to drop a couple hundred and a half for wipers. Might be nice to actually have wipers that work like they should on one of my old rides......That funny noise your hearing is probably the dollar bill I have a death grip on trying to scream. I just hate to let them go. I have never been accused of being a perfectionist, usually what the accuse me of is quite different. Gene
[Re: poorboy]
#972456
04/17/11 06:43 AM
04/17/11 06:43 AM
mafo
Finland
On the passenger cars wipers moves towards each other also but uses a "normal" motor, maybe it would be possible to use a similar system on a truck???
[Re: mafo]
#972457
04/17/11 09:02 PM
04/17/11 09:02 PM
poorboy
Freeport IL USA
The truck wipers swing towards each other as well. I suppose a guy could use a car wiper system on a truck, but I suspect you would need to have almost the complete system because I'm sure that length of the connecting arms would be a different length. Even then, you still have to convert to a 12 volt motor.
I've screwed with wiper systems on 30s through the late 50s Mopar cars and trucks, usually trying to adapt a modern readily available motor to the old wiper posts. Most times have been moderately usable. Currently, my 50 cab has the driver side wiper connected to a modified connecting arm (between the post and the motor arm), a modified motor arm and a mid 70s truck motor. I have it function on 2 speeds, but on high, the wiper blade (12" long) will hit both edges of the gasket. On low it stops right at the gasket. The current wiper stops wherever its turned off (does not park). As of yet (about 8 years) I have not bent anything, but I don't run on high very often. I have no wiper on the passenger side.
I've looked at single wiper motor, arm, & blade assembly like on a rear window of mini vans and such, but the sweep angle is too large for the trucks. A 48-53 truck needs a 90 degree sweep, most of the 1 piece windshields you might get away with a 120 degree sweep. I have heard the single wiper from a 60s era Jeep CJ would work, but no one can tell me the degrees of sweep those have either. Most of the wiper/blade assemblies have long blades as well that may cause a problem. Gene
