727 length VS 904 #972316
04/12/11 11:45 PM
04/12/11 11:45 PM
Clinton Twp. Michigan
coronet1966d Offline OP
i bought a 360 4bbl/727 drivetrain out of an 85 2wd ramcharger to swap into my 1981 new yorker that has a 360 4bbl with a 904 trans.
the 360 i bought already has the right manifolds and oil pan for my car but im wondering what ill run into as far as the trans is concerned, are the 727 and 904 the same overall lenght? what about my kickdown and shift linkage.. will they all bolt on?
Re: 727 length VS 904 [Re: coronet1966d] #972317
04/13/11 12:55 AM
04/13/11 12:55 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
727 is about 4 inches longer...drive shaft will need to be shorten..
also you might want to check on size of u-joints...the 904 generally use the smaller 7260 joint where as the 727 could use either one..
Tony
70 AARCuda Vitamin C
Re: 727 length VS 904 [Re: 70AARcuda] #972318
04/13/11 07:12 AM
04/13/11 07:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also if it's column shift you'll need shift linkage also since the bellhousing area maybe different.
Re: 727 length VS 904 [Re: coronet1966d] #972319
04/13/11 08:30 AM
04/13/11 08:30 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
You will also need a front drive shaft yoke for a 727
