Re: 413 rebuild
[Re: Hotlumpy]
#972118
04/13/11 05:58 PM
04/13/11 05:58 PM
Posts: 1,060 Ball Ground GA
TrueTripleX
Ball Ground GA
I ordered some yesterday off of Summit, Sealed Power 238P, They have a 2.000 Compression Height, but came to 9.85:1 compression with my 516 closed chamber heads. I measured the heads and came up with 69 cc's, and Summit has a compression calculator that works really well. What year of 413?
It's a 62 motor in a 62 300 convertible,
Re: 413 rebuild
[Re: TrueTripleX]
#972119
04/13/11 08:57 PM
04/13/11 08:57 PM
Posts: 166 California
Hotlumpy
California
If the heads are factory, they should be closed chamber 516 heads, and the Sealed Power 238P Pistons should work. I didn't have any luck through anyone but Summit, and the .040 over Pistons I ordered are not shipping out until 4/26. Good luck! Here is a link http://www.summitracing.com/parts/SLP-W238P40/ Compression calculator is on this link. Pistons are .085 deck clearance with the 2.000 compression height, have your heads cc'd and you're on your way.
