Piston Oil Ring Install #972080
04/12/11 03:29 PM
04/12/11 03:29 PM
Northern Virginia
barracuda7 Offline OP
Northern Virginia
I buy new set of piston Rings but I dont know how to install Oil Ring. This is my first time rebuilt.
There are balck and white indicators at each of end gap(picture below), instruction stated that they are BUTT OR LOCK TOGETHER, what does that mean, how can I lock or butt them together? Do I need to remove that black&white thing and overlap them??
Re: Piston Oil Ring Install [Re: barracuda7] #972081
04/12/11 03:35 PM
04/12/11 03:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Butt, means they TOUCH, do not remove them. Install that piece first the ends touch , not lock, then the other 2 rings .
Re: Piston Oil Ring Install [Re: JohnRR] #972082
04/12/11 04:16 PM
04/12/11 04:16 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Its also advised to position the ring gaps 120 degrees apart.
TOP oil ring @ 10:00
MIDDLE corrugated oil ring at 2:00
Bottom oil ring @ 6:00.
Re: Piston Oil Ring Install [Re: barracuda7] #972083
04/12/11 05:22 PM
04/12/11 05:22 PM
Wrap the (pictured) expander in the groove then install the top/bottom rails
Re: Piston Oil Ring Install [Re: RapidRobert] #972084
04/12/11 05:29 PM
04/12/11 05:29 PM
michigan woods
imfixinmopars426 Offline
michigan woods
there is usually instruction in the ring package. did they get misplaced? they might help w/ illustrations,mike
Re: Piston Oil Ring Install [Re: barracuda7] #972085
04/12/11 08:23 PM
04/12/11 08:23 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
They butt, not overlap or lock.
Re: Piston Oil Ring Install [Re: JonC] #972086
04/12/11 09:47 PM
04/12/11 09:47 PM
Northern Virginia
Northern Virginia
thanks a lot!
