TQ to lean....now what. #971902
04/12/11 12:16 PM
04/12/11 12:16 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
i have the TQ on the car and running but it seems very lean. even after idleing it around the plugs are white. i had a header off yesterday to change the starter ans the exhaust valves are white also. when driven it seems to run out of fuel and has a stumble. how can i richen this thing up. i have already taped the holes by the choke plate and have the mixture screws out as far as possible. 78 stock 440 ch4b adapter plate and TQ that is original to the eng.
thanks Shane
Re: TQ to lean....now what. [Re: 70rrclone] #971903
04/12/11 12:18 PM
04/12/11 12:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
drill out the jets or look on e-bay for some larger ones
Re: TQ to lean....now what. [Re: 70rrclone] #971904
04/12/11 12:18 PM
04/12/11 12:18 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Do you know where the metering-rod-tree is ?
Re: TQ to lean....now what. [Re: dOc !] #971905
04/12/11 12:26 PM
04/12/11 12:26 PM
La Grange, Ky
La Grange, Ky
Doc i know where the metering rod tree is, what should i do with it.
Shane
Re: TQ to lean....now what. [Re: 70rrclone] #971906
04/12/11 12:35 PM
04/12/11 12:35 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RUN that little screw IN(clockwise) say 3 turns ..
Is it doing this surging only uNder lite throttle ?
Re: TQ to lean....now what. [Re: dOc !] #971907
04/12/11 12:38 PM
04/12/11 12:38 PM
La Grange, Ky
La Grange, Ky
i'll try that. thanks Doc. it runs fine at lower speeds, but if you hit the gas it will take off then nose over.
Shane
Re: TQ to lean....now what. [Re: 70rrclone] #971908
04/12/11 12:41 PM
04/12/11 12:41 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
..and then INSTANTLY nose over ?
Re: TQ to lean....now what. [Re: dOc !] #971909
04/12/11 12:43 PM
04/12/11 12:43 PM
La Grange, Ky
La Grange, Ky
it takes about 5-10 secs to nose over at 1/2 to 3/4 throttle.
Re: TQ to lean....now what. [Re: 70rrclone] #971910
04/12/11 12:50 PM
04/12/11 12:50 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I would look on the SECONDARY side of the carb. 5-10 seconds ? .. that is on that side of it. How do you have the secondary AV adjusted? How is your fuel pressure too?
The crab sounds like a sweety-pie on the primary side ...I would not touch it.
Re: TQ to lean....now what. [Re: dOc !] #971911
04/12/11 01:00 PM
04/12/11 01:00 PM
La Grange, Ky
La Grange, Ky
i have not touched the air valve yet.should i try to tighten or loosen it. should i still adjust the metering tree? is it running too lean with the white plugs and valves?
i will have to check the fuel pressure. stock fuel pump nothing fancy.
Shane
Re: TQ to lean....now what. [Re: 70rrclone] #971912
04/12/11 01:04 PM
04/12/11 01:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
DO this test ...with the carb at WOT ... how EZ is it to press-down on the flapper-valve ?
Re: TQ to lean....now what. [Re: 70rrclone] #971913
04/12/11 01:05 PM
04/12/11 01:05 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
If it is a jetting issue, test this way:
drive the vehicle, and as soon as the nose-over starts, back off the throttle just a bit(not much)and if the engine picks up again, jetting
richer is a must. If the engine does not pick up, then the problem is
something else such as fuel flow or pressure, David.
Re: TQ to lean....now what. [Re: 70rrclone] #971914
04/12/11 01:08 PM
04/12/11 01:08 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
almost ferrgot.... leave the primary side alone for now. LOTS of Berri Bumz would KILL for a carb as sweet as that one on the primary side..
Re: TQ to lean....now what. [Re: dOc !] #971915
04/12/11 01:14 PM
04/12/11 01:14 PM
La Grange, Ky
La Grange, Ky
Thanks Doc and Demon ill give that stuff a look
Shane
