Re: 6 pack setup
[Re: kevinRT]
#971809
04/12/11 10:15 AM
04/12/11 10:15 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
does anyone know if you can fit a 340 with a stock 6 pack setup under a rally hood? or does it only fit with aar hood, and if not how much more room does it need?/
Don't see why not , the 440 with a 6pak fits under the rallye hood.
Re: 6 pack setup
[Re: JohnRR]
#971810
04/12/11 10:47 AM
04/12/11 10:47 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
my stock 440-6 intake a carbs barely fit under the stock 70 charger hood. It was up into the padding.
Re: 6 pack setup
[Re: Mr.Yuck]
#971811
04/12/11 11:24 AM
04/12/11 11:24 AM
JohnRR
U.S.S.A.
Jeff , yor chargers issue does not answer this question. The OP has an E body with a rallye hood, the rallye hood has a raised center. E bodies came factory installed with 440's and 6 paks. Also the 440 and the 340 used the same air cleaner base on fresh air hood cars. There will be no clearance issue with the setup the OP wants to run.
Your car , Chargers have low hood lines , but they came equipped with 6paks and hemis with oval air cleaners so it doesn't seem to be an issue , lose the hood pad
Re: 6 pack setup
[Re: JohnRR]
#971812
04/12/11 11:28 AM
04/12/11 11:28 AM
Mr.Yuck
Brookeville, Md
I did better I lost the hood. Had too, not a chance it fits now w/ the stage VI heads, intake spacers and 1/2 carb spacer for the meth. His should fit under the e-body rallye hood.
Re: 6 pack setup
[Re: kevinRT]
#971815
04/13/11 11:55 PM
04/13/11 11:55 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
Just to confirm, factory intakewith factory six pack and aircleaner under rally hood? by the way nice job thanks in advance
intake yes, carbs yes,air cleaner base plate is a fiberglass repo (same dimemsions as factory) and rallye hood yes!
