New 383 not Running Right ??????? #971798
04/12/11 08:26 AM
04/12/11 08:26 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
My 70 383 started not running right coming home Sat. eve. It was pinging at certain hwy. speed an would not idle. I checked my timing and adjusted it some and reset the carb. Now it is back where it will idle but I haven't got to drive it yet. The dist. wasn't real loose but it would move fairly easy. I had just changed the valve cover gasket and was wondering if I could have hit it and moved it. I have got a road trip SAT. so I need to get it figured out. Any one have any ideals? Thanks Ronnie
Re: New 383 not Running Right ??????? [Re: okie] #971799
04/12/11 09:20 AM
04/12/11 09:20 AM
The dist. wasn't real loose but it would move fairly easy. I have got a road trip SAT. so I need to get it figured out. Any one have any ideals?
Retime it & snug the clamp
