Cast crank Torque converter question #971730
04/12/11 12:24 AM
04/12/11 12:24 AM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I have a 75 440 HP with a cast crank it has 6 bolts on the back flex plate side if the crank. The dampner says for cast crank only. Do I need the torque converter with weights on it or without the weights?
Re: Cast crank Torque converter question [Re: Boise Chall] #971731
04/12/11 12:53 AM
04/12/11 12:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Definitely WITH the weights OR use a flywheel that is balanced, along with a neutral balance converter. B&M used to sell a 440 CAST crank flywheel that had a "crescent" cutout opposite of where the torque converter weights were. I'm not sure if it is still available.
Re: Cast crank Torque converter question [Re: Kern Dog] #971732
04/12/11 06:27 AM
04/12/11 06:27 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I'm pretty sure it is. I've recently seen them.
Re: Cast crank Torque converter question [Re: POS Dakota] #971733
04/12/11 07:10 AM
04/12/11 07:10 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
You need a weighted converter with a cast crank. OR a use a weighted after market flex plate for cast crank shaft with a non weighted converter. But not both a cast shaft flex plate and a weighted converter.
Re: Cast crank Torque converter question [Re: Kern Dog] #971734
04/12/11 09:56 AM
04/12/11 09:56 AM
Boise Idaho
Boise Idaho
Thank you for the quick reply. I will let the guy building the tranny know.
