68 b-body booster interchange
#971698
04/11/11 11:42 PM
04/11/11 11:42 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
i have a 68 satellite with a drum brake booster,single diaphram. will the dual diaphram booster,to suit factory disc/drum,bolt up without any modification ? thanks, Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 68 b-body booster interchange
[Re: 1_WILD_RT]
#971700
04/12/11 06:44 PM
04/12/11 06:44 PM
tex013
Sydney,Australia
thanks, has anyone used the NAPA supplied booster/master cylinder.dual diaphram
Tex
