bellhousing question #971656
04/11/11 11:07 PM
04/11/11 11:07 PM
houston texas
gremlinsteve Offline OP
houston texas
i have a small block v8 bellhousing from a van. has the window with the timing marks on it. also has the bellhousing mounted ball.
i am doing a bit of gathering for a 4 seed sap into a 67 b body. will this bellhousing work for me on this swap?
trying to bolt a a833 4 gear on this motor and ran into this issue. just wondering if its worth my time at this point to use this part or search for another.
steve-o
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: bellhousing question [Re: gremlinsteve] #971657
04/12/11 12:08 AM
04/12/11 12:08 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Scrap it and buy a pass car one.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: bellhousing question [Re: Dan Brewer] #971658
04/12/11 12:33 AM
04/12/11 12:33 AM
houston texas
houston texas
ahhhh foooot!!!!!!!!!!
guess ill just bite the bullet...got scammed on this one.
steve
