Engine Oil----Whats best to use? #971596
04/11/11 10:04 PM
04/11/11 10:04 PM
Ontario, Canada
72HemiCuda Offline OP
Ontario, Canada
Spring is here and time to do the regular maintenance before starting up the engines. Every year I get a different story on the type of oil I should be using on the old stock 68 hemi. I have even heard that some guys are putting diesel oil into their big blocks. Some say to add a ZDDP additive along with the oil the normally use and others say to try to use ZDDP in it. What oil is everyone using? Maybe we can come to a consensus and help each javascript:void(0)other out. Any help would be appreciated.
Re: Engine Oil----Whats best to use? [Re: 72HemiCuda] #971597
04/11/11 10:08 PM
04/11/11 10:08 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Ah! Another which oil to use question! I use Brad Penn 10w30 Plenty of zinc/phophates.
Re: Engine Oil----Whats best to use? [Re: superbeedave] #971598
04/11/11 10:54 PM
04/11/11 10:54 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
you'll get many opinions! Brad Penn 20w50 for me!
Re: Engine Oil----Whats best to use? [Re: superbeedave] #971599
04/11/11 11:00 PM
04/11/11 11:00 PM
IN
ahy Offline
ahy  Offline
IN
Lots of ways to skin a cat... I believe regular oil + ZDPP is good, Brad Penn and some of the racing oils are good, Mobile 1 20W50 is good.
My choice is diesel engine oil + STP which is good also. Also readily available and cost effective. 7000 miles on moderatly fairly aggressive flat tappet and no issues.
What's best? I don't know...
Re: Engine Oil----Whats best to use? [Re: ahy] #971600
04/11/11 11:40 PM
04/11/11 11:40 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
You're not going to go wrong with the Brad Penn stuff.It has the correct amount of zinc for your engine.
You're also not going to go wrong with the Valvoline VR-1 racing oil either(which is far cheaper)
I use the Valvoline on my 383 'cuz it's cheaper,but would you really wanna "cheap-out" on a HEMI ?
Re: Engine Oil----Whats best to use? [Re: jcastle1] #971601
04/12/11 12:10 AM
04/12/11 12:10 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Castrol GTX 20w-50 or Rotella Shell 15W-40, either and a bottle of Comp Cams 152 break-in lube.
Re: Engine Oil----Whats best to use? [Re: 72HemiCuda] #971602
04/12/11 02:27 AM
04/12/11 02:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just changed my oil, used valvoline VR1 20w-50 with a bottle of Redline Engine Breakin lube.
From Redlines Web Page
"Bottle (16oz) contains:
33.8 grams total ZDDP (zinc dialkyldithiophosphate)
17,000 ppm, 7.8 grams Phosphorus (P)
20,500 ppm, 9.4 grams Zinc (Zn)
16.6 grams Sulphur (S)"
Increases of antiwear per quart by using one bottle (16oz.): Oil capacity:
Phosphorus Zinc
15 quarts 610 ppm 736 ppm
12 quarts 763 ppm 920 ppm
10 quarts 915 ppm 1104 ppm
8 quarts 1145 ppm 1380 ppm
7 quarts 1307 ppm 1577 ppm
6 quarts 1525 ppm 1840 ppm
5 quarts 1830 ppm 2208 ppm
4 quarts 2288 ppm 2760 ppm
1 quart 9160 ppm 11040 ppm
Half Bottle (8oz.) When Treating:
12 quarts 382 ppm 460 ppm
10 quarts 458 ppm 552 ppm
8 quarts 572 ppm 690 ppm
6 quarts 763 ppm 920 ppm
5 quarts 915 ppm 1104 ppm
4 quarts 1145 ppm 1380 ppm
Re: Engine Oil----Whats best to use? [Re: 72HemiCuda] #971603
04/12/11 07:48 AM
04/12/11 07:48 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I’d just find a good oil you’re comfortable with using and already has the proper blend of ZDDP or other anti-wear additives. Some already mentioned some good ones here.
Buying a properly blended and balanced finished product is different than dumping various aftermarket oil additives in to your crankcase. It’s a balancing act and you could be doing more harm than good by blending your own. Why do it with so many good options out there?
Re: Engine Oil----Whats best to use? [Re: CompSyn] #971604
04/12/11 10:34 AM
04/12/11 10:34 AM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
I don't know why anyone would want to play chemist with additives when there are correctly formulated oils available off the shelf.
Re: Engine Oil----Whats best to use? [Re: Aero426] #971605
04/12/11 12:29 PM
04/12/11 12:29 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I used Z-Alt for the first time in my cars last year. I was pretty impressed. Both cars ran well, sounded good, oil held up well.
I am always cynical about product claims, but the oil did seem to make the engines a little quieter, which is what they claim.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Engine Oil----Whats best to use? [Re: 72HemiCuda] #971606
04/12/11 01:38 PM
04/12/11 01:38 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I use the oil that my neighbor drains out out of his diesel RV....
Re: Engine Oil----Whats best to use? [Re: Commando1] #971607
04/12/11 02:18 PM
04/12/11 02:18 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I use Crisco oil off the shelf at the supermarket.
Honestly, I've often wondered if it would work...
Re: Engine Oil----Whats best to use? [Re: POS Dakota] #971608
04/12/11 03:24 PM
04/12/11 03:24 PM
MoreParts Offline
MoreParts  Offline
I use Redline's 10w30. One of the highest rated synthetics on the market formulated with the proper levels of zddp for our cars. The trouble with adding zddp to your own oil is you don't know if it will counter act with some of the existing detergents formulated in.
Re: Engine Oil----Whats best to use? [Re: MoreParts] #971609
04/12/11 05:22 PM
04/12/11 05:22 PM
michigan woods
imfixinmopars426 Offline
michigan woods
vr1 10w30 in the charger,much cheaper than the "joe gibbs" oil at the store...9.99-12.99 qt vs 4.00 qt! and others here have found vr1 cheaper at autozone,ect than the $4 i paid.. ..after i did a search on mopars... ..DUH!
Re: Engine Oil----Whats best to use? [Re: imfixinmopars426] #971610
04/12/11 05:29 PM
04/12/11 05:29 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
brad penn in all my engines!
a friend bought a pallet and paid less than 4 bucks a qt. (that was last summer)
unions....the folks who brought you the weekend!
Re: Engine Oil----Whats best to use? [Re: imfixinmopars426] #971611
04/12/11 07:49 PM
04/12/11 07:49 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i thought the vr1 10 30 was SM rated.
Re: Engine Oil----Whats best to use? [Re: 72HemiCuda] #971612
04/12/11 09:21 PM
04/12/11 09:21 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
15W40 Diesel oil (aka heavy duty oil) and a bottle of STP. Works for me.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Engine Oil----Whats best to use? [Re: Junky] #971613
04/12/11 09:24 PM
04/12/11 09:24 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Rotella 15/40 with STP also.
