Bolt-on replacement options for 5.9 Magnum heads? #971257
04/11/11 04:32 PM
04/11/11 04:32 PM
VA
AtomicDog Offline OP
VA
My machine shop has told me that the 5.9 Magnum heads off my motor are cracked. I need to pickup some replacement heads. I understand that junkyard Magnum 5.9 heads are prone to the same issue, as it seems that the castings are poor on these heads.
So, I'm in need of some replacement heads. I want heads that are a total bolt-on replacement. I thought about Edelbrock heads, but they require new rocker arms, studs and pushrods. In addition, I'm not doing any upgrades to the short block, so what are my possible options for replacing my existing magnum heads with something that is not crack-prone?
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: AtomicDog] #971258
04/11/11 04:39 PM
04/11/11 04:39 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The consesus will be Carolina machine and Hughes engines. New iron heads based on the OEM head design but better quality and better function.
Keep old mopars alive.
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: 2boltmain] #971259
04/11/11 04:47 PM
04/11/11 04:47 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Two good options are:
RHS/Indy
EQ "Iron Ram"
Both can be had at Hughes assembled as "factory replacement" but with better springs.
If you want to go with upgraded components/more prep, then Hughes has that too, but IMM (board member OU812) has package for valve job, prep, upgraded components that's a good deal.
As I'm sure other businesses here have...
Good luck,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: AtomicDog] #971260
04/11/11 05:59 PM
04/11/11 05:59 PM
VA
VA
Is an iron head my only choice? Anyone make a budget aluminum Magnum head?
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: AtomicDog] #971261
04/11/11 06:50 PM
04/11/11 06:50 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You can go with Eddys, but there around 1400.00 & still need to be checked, No "budget" Alum. SB head that i know of. The base line RHS heads flow VERY well, I got mine from Hughes engines "ready to bolt on" all oiled up & checked for any issues for 875.00, The EQs at the time were on back-order, I would think they have them now, The base RHS Magnum heads flow alittle better then the EQs.
http://www.hughesengines.com/Index/produ...mp;partid=25738
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: joedust451] #971262
04/11/11 06:55 PM
04/11/11 06:55 PM
VA
VA
No one else offers a decent aluminum Magnum style head?
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: AtomicDog] #971263
04/12/11 11:03 AM
04/12/11 11:03 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
best bet for the money:
http://www.hughesengines.com/Index/produ...mp;partid=25701
new EQ heads, can resuse stock valve gear, has upgraded springs and new OEM valves...
while you're at it I'd send them your roller cam and pick up one of their regrinds, probably the HER0814AL if it's in a workaday truck....
2017 Grand Cherokee Overland
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: AtomicDog] #971264
04/12/11 11:35 AM
04/12/11 11:35 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Um...the Edelbrocks have been mentioned a few times in this thread now...How much do you wanna spend? They'll cost you $1400.
Eddy RPM Magnum Heads at Jegs
basically, your options for buying brand new castings are either $800 for factory style iron heads, or $1400 for performance style aluminum heads. been that way for years when it comes to Mopar stuff...and there aren't ANY iron factory style heads being cast brand new for big blocks that I know of. everything is either aftermarket performance based, or re-worked factory heads.
**Photobucket sucks**
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: 70Cuda383] #971265
04/12/11 01:08 PM
04/12/11 01:08 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
nevermind...I misread the post I quoted! I read "does anyone make an aluminum magnum head" not "does anyone ELSE make an aluminum magnum head"
to my knowledge, edelbrock is your only aluminum head source for a decent street head.
all others are iron.
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: 70Cuda383] #971266
04/12/11 02:20 PM
04/12/11 02:20 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Wasnt pro comp making an aluminum smallblock head? What's the status of that?
I thought someone had these in hand and was supposed to come back with data? I know I read it HERE.
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: patrick] #971267
04/12/11 02:33 PM
04/12/11 02:33 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Though these are a better price then the RHSs, they don't flow as good on the intake as do the RHSs, the RHSs are 150.00 more.
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: joedust451] #971268
04/12/11 02:38 PM
04/12/11 02:38 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Another thing that needs to be addressed is, If he will be running the factory pistons, Going with Aluminum heads the compression should be raised a good full point to compensate, so theres another exspence unless he mills the Aluminum heads. IMO it isn't worth it, The RHSs flow just as good or very close as the Eddys OOTB between the both.
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: joedust451] #971269
04/12/11 05:23 PM
04/12/11 05:23 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
please let this myth die...you CAN increase compression, but you don't HAVE to.
BTW the eddie chambers are ~5cc smaller than OEM (and EQ and RHS) maggies
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: patrick] #971270
04/13/11 09:20 AM
04/13/11 09:20 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I agree with Patrick.
I got on a kick about 3 years ago
and became curious about:
"How much extra heat leaks away from a cylinder head made of aluminum,
versus one made of cast iron"
I posted a question here on Moparts titled
"Efficiency of aluminum vs iron heads"
which eventually grew to 30 to 40 replies and posts,
with many external links,
including this one:
http://www.carcraft.com/techarticles/ccrp_0602_iron_versus_aluminum_cylinder_heads_test/index.html
After further research
including reading the heat transfer sections of several college engine textbooks,
the conclusion was:
"There is no efficiency
or power disadvantage
to aluminum heads,
and there may be a 2 to 3% advantage"
Why is this
since 'everbody knows'
aluminum has a higher thermal conductivity (K)
than cast iron?
The highly technical reason is:
"The rate of Heat Transfer from the combustion gases to the metal walls is dependent on a series of steps,
like links in a chain,
and the 'weakest link'
is at the 'boundary layer'
where hot gas touches cooler metal.
Since the boundary layer is about the same in both types of cylinder heads,
the 'real world' heat transfer is also about the same.
Richard Stone's book has a graph showing Japanese research on aluminum versus cast iron cylinder heads:
http://www.amazon.com/Introduction-Inter...7025&sr=1-4
Are there any NOS remnants of this older
P5153847 MP aluminum cylinder head?
http://www.moparsupercenter.com/mopar-pe...47p5153847.html
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: 360view] #971271
04/13/11 10:58 AM
04/13/11 10:58 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
360view,
Thanks for that excellent info. It seems everyone has a "rule" for aluminum heads from "you must raise compression" or they "drop compression".
In the end, when I bought the Edelbrocks for my 408 stroker I came to the conslusion that compression ratio stays the same (built mine for 10:1 nice and safe on pump gas) but you can run a higher compression ratio before you start to see negative effects with the aluminum heads.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Bolt-on replacement options for 5.9 Magnum heads? [Re: finadk] #971272
04/15/11 10:18 AM
04/15/11 10:18 AM
VA
VA
Thanks for all of the info and replies. Was hoping that the Magnum 5.9 head options might be widening, especially for aluminum head options like what is being done for the big blocks - for example:
http://store.440source.com/Stealth-Aluminum-Cylinder-Head-COMPLETE-SINGLE-HEAD/productinfo/200-1055/
