Another 383 question #970992
04/11/11 12:33 AM
04/11/11 12:33 AM
California
court9155 Offline OP
California
Did all the pre 68 383s have the bolt holes drilled and tapped for the A body mount?
I ask because I have a 67 383 with the holes drilled and tapped for the driver side mount.
I also have a 68 and a 69 block and there is a boss there but not drilled and tapped.
Just curious if maybe I have an A body 67 383 block but I thought I read somewhere that early c bodies used this weird mount too...
Anyone shed some light on this?
Dan
67 charger
Re: Another 383 question [Re: court9155] #970993
04/11/11 01:06 AM
04/11/11 01:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
67 C bodies used the mount that went off the front of the block so all 383 blocks would be drilled and tapped whether they were destined for a C body ... or A body ... or not ... the a body also had an ear on the drivers side machined off that all others would not .
Re: Another 383 question [Re: JohnRR] #970994
04/11/11 01:07 AM
04/11/11 01:07 AM
California
California
Happen to have a picture of this?
67 charger
Re: Another 383 question [Re: court9155] #970995
04/11/11 01:08 AM
04/11/11 01:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No I don't, it's the rear ear that is all by itself , it would not be there if it were an A body engine .
Re: Another 383 question [Re: JohnRR] #970996
04/11/11 01:24 AM
04/11/11 01:24 AM
California
California
Then maybe it is an a body engine because it looks exactly like this:
It is stamped C383 on the pad and has a 2 66 date code wouldnt that be a bit early for an A body 383?
Just curious gonna put this in my charger regardless but if someone needed it bad enough id help them out for sure.
67 charger
Re: Another 383 question [Re: court9155] #970997
04/11/11 01:33 AM
04/11/11 01:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is that YOUR engine in that picture?
I don't know when the 67 A bodies started having big blocks so I can't answer.
As far as you helping some one, it depends if the premiumn you put on the parts you are flipping is cheaper than machining a block that has the nubs not machined. The rear ear doesn't need to be removed unless the car has power steering and even then it may only need a slight grinding.
Re: Another 383 question [Re: JohnRR] #970998
04/11/11 01:36 AM
04/11/11 01:36 AM
California
California
The picture is exactly what my block looks like, however, that is not MY engine but I have the copy of it lol.
Im not tryin to make any loot or anything, matter of fact the engine is goin in my charger for now because it is a fresh motor with 30 over slugs and a small camshaft along with rebuilt 516 heads. I was only askin some questions.
If someone absolutely had to have it then they would have to give me another 383 that is a fresh motor to use in my charger.
67 charger
Re: Another 383 question [Re: court9155] #970999
04/11/11 01:45 AM
04/11/11 01:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would just use it , the list of people that have to have that block and pay money on top of giving you a fresh engine is very short .
Re: Another 383 question [Re: JohnRR] #971000
04/11/11 01:52 AM
04/11/11 01:52 AM
California
California
Gonna use it and if someone gimme a fresh motor in exchange for this fresh motor I wouldnt want a dime, especially if it helped them out with their mopar dude.
Anyway when I pull it out down the road I know it is possibly unique which is way cool.
67 charger
Re: Another 383 question [Re: JohnRR] #971001
04/11/11 03:49 AM
04/11/11 03:49 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 383 Barracuda and Dart models started showing up in late March 1967. I wouldn't expect to see an original car to have a block with a casting date prior to Dec. 66 to Jan. 67.
Re: Another 383 question [Re: court9155] #971002
04/11/11 09:04 AM
04/11/11 09:04 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
What are you going to bolt the B-body Charger motor mount to?
Re: Another 383 question [Re: GomangoCuda] #971003
04/11/11 03:56 PM
04/11/11 03:56 PM
California
California
The motor was in a b body so imma use the mount thats on it right now. Ill post a pic.
Dan
67 charger
Re: Another 383 question [Re: court9155] #971004
04/12/11 11:49 AM
04/12/11 11:49 AM
California
California
Well guys thanks for all your time and help. Looks like Im a crackhead tho. The rear motor mount tab is there and has a bolt through it (motor mount bracket) duh. Dont know how I missed it.
But hey, atleast I dont have to worry about using a factory A body big block in my charger when someone could use it....its not one.
Dan
67 charger
