Re: msd 12 volt switched source question
[Re: 440forPOWER]
#970402
04/10/11 05:21 PM
04/10/11 05:21 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
For a switched source for the MSD simply eliminate the ballast resister and splice the wires on both sides of it together and use the original coil (+) wire as the switched source.
Or you can leave the ballast in position and use the coil (+) wire as a switched source; the MSD doesn't care about the voltage in the switched wire, it merely turns the unit on/off.
