General paint question #97021
07/30/08 10:57 AM
07/30/08 10:57 AM
Leetonia, OH
R6T8net Offline OP
R6T8net  Offline OP
Leetonia, OH
With a "quality" paint job on a full rotisserie resto, what is the typical process for painting? Is the unit body completely painted (base and clear coat) seperately from the fenders, doors, hood, etc. or is everything done partially, assembled and then finished? Seems to me that latter would have to happen to get things right and, if so, what is the procedure?
"Who is John Galt?"
68 Coronet RT LL1 Auto
70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far
01 2500 Quad Cab 4x4 Cummins
Re: General paint question [Re: R6T8net] #97022
07/30/08 12:27 PM
07/30/08 12:27 PM
cataclysm80 Offline
cataclysm80  Offline
What I usually see is everything dissassembled, repaired, epoxy primed, Test fit sheetmetal lining up all gaps etc, test fit anything else that goes on the car (trim, grill, mirrors, sill plates, door panels, everything cause you don't want to fix it after paint!), with sheetmetal still installed (but nothing else) block sand the car, block sand the car again, block sand the car again, wet sand the car, carefully remove the sheet metal keeping track of any shims and where they go, paint all the sheetmetal base & clear, paint the unibody base & clear, extremely carefully reinstall sheetmetal, color sand, buff, polish.
Note: This is different from the OE procedure which is basically to apply a rust preventative to the metal to metal contact areas (like under the door hinges), Then install all sheetmetal, and primer then paint the car. Any areas that get missed, Oh well.
Tav
Re: General paint question [Re: cataclysm80] #97023
07/30/08 08:25 PM
07/30/08 08:25 PM
Leetonia, OH
R6T8net Offline OP
R6T8net  Offline OP
Leetonia, OH
Thanks for the info
"Who is John Galt?"
Re: General paint question [Re: R6T8net] #97024
07/30/08 08:47 PM
07/30/08 08:47 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Mine was original sheet metal so fit problems were not a concern. Painted apart, hang and set doors correctly, hang and fit fenders to doors, install valences and header panel to fenders, fit hood and adjust as necessary, hang trunk lid. Everything fit perfectly, and seams and gaps are beautiful. Just my experience on this serious of paint work.
Careful, your character's showing!
Re: General paint question [Re: mopar346] #97025
07/30/08 09:03 PM
07/30/08 09:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My gold 71 was done like that, You know what? After I put that baby loving together, I started to notice every panel was a little different color ... After a bout a year it got worse!!!!
luckly my painter disassembled alot of my car and repainted the whole thing. At his cost every penny. He did'nt want any paint lines anywhere the first time but the metalic color gold bite him in the rear , but he made it right. It still sucked having to repaint the car a second time after a complete resto. My
Re: General paint question [Re: Challenger 1] #97026
07/30/08 09:27 PM
07/30/08 09:27 PM
Kirkland, Washington
Pacnorthcuda Offline
Painting a metallic with panels off is a crapshoot and best avoided. While some get away with with it, many do not. Opaque colors can be done that way but even then the painter is wise to make sure the SAME paint (I.E. can/batch) is used, on the same day, same number of coats etc.
Metallics should be painted as a complete car. Candies are the hardest--you're litterally dealing with transparent paint. I learned that in the 7th grade painting a candy-apple red 10 speed.
Re: General paint question [Re: Pacnorthcuda] #97027
07/30/08 10:24 PM
07/30/08 10:24 PM
mopar346 Offline
mopar346  Offline
Well its FK5 if that matters, but it was painted same time, same coats, same batch/can, so hopefully I'll be fine, don't jynx me.
It hasn't been out in the sun to any extent and it is about 4 years old at this point (I'm on the 10 year plan too).
Re: General paint question [Re: mopar346] #97028
08/01/08 07:40 AM
08/01/08 07:40 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
If the car is painted in pieces, how do you get paint on the bolt heads? I'd paint it assembled.
Re: General paint question [Re: 375inStroke] #97029
08/01/08 07:48 AM
08/01/08 07:48 AM
cataclysm80 Offline
cataclysm80  Offline
bolt heads can be painted separately, but I do know a guy that paints his cars apart except for the engine compartment then uses a spray mask on the painted stuff, and paints the engine compartment last after the sheetmetal is back on, just so that his fender bolts look good. Cars that he paints regularly win trophies at local shows.
Tav
