68 b-body steering column work in 67 b-body #970173
04/10/11 12:43 AM
04/10/11 12:43 AM
St. Paul, MN
stat5 Offline OP
stat5  Offline OP
St. Paul, MN
Will a 68 b-body power steering column work in a 67 b-body power steering car? If it works, is it a straight swap in or does anything on the 68 column have to been change?
Thanks for any and all answers
Re: 68 b-body steering column work in 67 b-body [Re: stat5] #970174
04/10/11 02:40 AM
04/10/11 02:40 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i just put a 67gtx colunm in a 68 dodge coronet, took out the 68 and put in the 67 no problems*
Re: 68 b-body steering column work in 67 b-body [Re: stat5] #970175
04/10/11 05:44 PM
04/10/11 05:44 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
One thing to be aware of on a column shift column -
If the column came from a LATE '68, it probably won't have the provision for the column mounted reverse light switch. I found this out on my wagon; it's a late car and has the '69-up rev light / neutral safety combo switch in the trans and no switch on the column.
If you're doing a floor mounted column, it's not an issue, the switch is at the shifter.
