Dana 60 pinion snubber???? #970152
04/10/11 12:09 AM
04/10/11 12:09 AM
indiana,usa
donsbelvedere Offline OP
indiana,usa
Hello , just installed a Dana 60 in my 1966 B-Body.There no pad on the Dana to install the pinion snubber,So do I install it on the pan faceing down toward the housing or what the correct way?Thanks alot....Donnie
Re: Dana 60 pinion snubber???? [Re: donsbelvedere] #970153
04/10/11 12:13 AM
04/10/11 12:13 AM
Florida STAYcation
dIc dOc Deity ! Offline
The village idiot's idiot
Florida STAYcation
CORRECT WAY ? ...no snubber .. just get the proper springs .....
Re: Dana 60 pinion snubber???? [Re: donsbelvedere] #970154
04/10/11 12:39 AM
04/10/11 12:39 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
You must have a truck or aftermarket center with no plate mount provision. So you cant use a pinion snubber. For what you have there is no correct way.
