NEED SOME HELP BADLY........WIRING!!!!! #970089
04/09/11 08:51 PM
04/09/11 08:51 PM
nebraska
69coronet440 Offline OP
nebraska
I ran out of patience and need anybodys help right now. I just replaced all my electrical wiring(DASH,ENGINE,HEADLIGHT,TAILLIGHT) in my 69 coronet r/t because of a big meltdown. During this time I also upgraded to a one wire chrysler 100amp alternator and an HEI distributor. I hooked the alternator up to the original engine wiring(new harness) just the one wire, and left the others along? Got rid of regulator and so forth. I don't know if this was the correct way or not?
Ok , as far as the HEI distributor I hooked the neg wire to the neg on coil and pos. on pos.. Ok I hooked the battery up and gave it a try. HERES THE PROBLEM. It will start only if I keep the ignition engaged. once I let off the key It looses power and quits. WHY WON"T IT STAY RUNNING? Also my dash lights don't work now and my taillights don't work. Its all new wiring. I'm getting pissed please help? THANKS!!!!!
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970090
04/09/11 09:04 PM
04/09/11 09:04 PM
Under My Car
Mopar_Country Offline
Under My Car
If it will run as long as you hold the key and when you let go of it to the run position it dies, check your ballast resistor. You can put a jumper in place of the ballast to find out if that's the problem.
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: Mopar_Country] #970091
04/09/11 09:13 PM
04/09/11 09:13 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
i agree with the ballast restistor. as for the dash and tail lights i would check the bulkhaed connection. did a new bulkhead connector block come with the new wiring? do you have a wiring diagram? classic car wiring has a great color diagram.
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970092
04/09/11 09:18 PM
04/09/11 09:18 PM
nebraska
nebraska
I will try the jumper wire. As far as the dash lights. Everything plug in were the old wiring was? I'm going to check and makes sure my cluster is grounded good also.THANKS FOR THE HELP!
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970093
04/09/11 09:24 PM
04/09/11 09:24 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
do you have voltage to one side of your light switch? if you do not then you have no voltage thru the bulkhead connector. wiggle the harness at the bulkhead with the light switch pulled on if the lights blink there you go.
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: lokalik] #970094
04/10/11 11:43 AM
04/10/11 11:43 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
sounds like you only used the brown wire(start) from the ignition switch- you need to add the dark blue wire also.
dark blue- power with key on
brown- power only on start
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970095
04/10/11 11:52 AM
04/10/11 11:52 AM
Jason are you in Lincoln
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970096
04/10/11 12:59 PM
04/10/11 12:59 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
The one wire alternator connects directly to the battery not the factory harness. I ran a 10 gauge wire from the alternator to the battery or positive lug on the starter
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970097
04/10/11 01:55 PM
04/10/11 01:55 PM
nebraska
nebraska
I'm about 100 miles from lincoln. I will hook up the wire on the alternator today. I did get it to run with the wire jump but as it shuts off it spits through the carb? Never did this before? THANKS FOR ALL THE HELP. Hope I can get everything working properly. I'm not a wiring guy?
Re: NEED SOME HELP BADLY........WIRING!!!!! [Re: 69coronet440] #970098
04/10/11 02:10 PM
04/10/11 02:10 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
As was mentioned earlier. Mopars have a Start 1 & Start 2 for the ignition power. The cranking one is a direct 12v circuit that bypasses the reduced voltage from the ballast resistor to help with hot and cold starts.
The 12V power that goes through the ballast resistor is actually reduced in voltage to about + - 8v. That's the one that runs the car after it's started. I believe it was done to increase the life of the points and coil.
Also, you may want to upgrade your alternator wiring/routing, bulkhead bypass and bypass the amp guage to improve your system's reliability & performance.
If you can, talk RapidRobert in to coming over to help you out for a few hours. He know's his stuff.
