Re: Removing stuck pistons/rods
[Re: Lifsgrt]
#970018
04/09/11 06:50 PM
04/09/11 06:50 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
soak the piston holes with brake fluid... KRIOL or Marvel Mystery oil works well to but is more expensive...
I am truckless..
[Re: dIc dOc Deity !]
#970020
04/09/11 07:07 PM
04/09/11 07:07 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Yes, crank still installed. Last time I tried this on an engine I banged up a couple of rods and nicked the crank. Is there a way to break the pistons to release the pins without hurting the block or rods?
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
#970022
04/09/11 09:59 PM
04/09/11 09:59 PM
Lifsgrt
I must be a terrible communicator. I have a 383 with the pistons stuck on the rods, in the cylinders, crank is still installed. I'll call it a shortblock. I want to tear the engine down while saving the rods, crank, and block. Last time I tried this on a 440, the pins were seized in the pistons, and the rods wouldn't pivot on the pins, which will not allow the piston to be pushed/driven up into the cylinders. I bent up a couple of rods and nicked the crank. Thought maybe someone on here would have the answer, short of hot-wrenching the rods. Anyone?? Bueller?? Thanks
#970024
04/09/11 10:41 PM
04/09/11 10:41 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
KRIOL will do the trick spray the top and left it soak in.Then do it from the bottom.Couple times a day for a few days.Be patient.A few hits with a deadblow hammer on the pistons should finish loosening them.You may need to sleeve a few holes if they are rusted too bad.
Leave the gun.......take the Cannoli's....Mike
