$125 for a valve cover gasket?!?!?! #969977
04/09/11 05:04 PM
04/09/11 05:04 PM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Was going to adjust the valves on my 01 Cummins, cheapest I found locally was $125 for the valve cover gasket. I've done other valve covers similar to the Cummins and they weren't $125 for a lousy gasket...
Any better alternatives? After 10 years, is the gasket likely reusable?
Re: $125 for a valve cover gasket?!?!?! [Re: Sixpak] #969978
04/09/11 05:18 PM
04/09/11 05:18 PM
West Palm Beach, Florida
Rockland71GTX Offline
Rockauto has it for~ $80
Re: $125 for a valve cover gasket?!?!?! [Re: Rockland71GTX] #969979
04/09/11 06:17 PM
04/09/11 06:17 PM
Central TX
roe Offline
roe  Offline
Central TX
Why not make your own from a roll of gasket making material. Thats what I did with some of my smaller gaskets that required an oil resistants material, like my dizzy.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: $125 for a valve cover gasket?!?!?! [Re: Sixpak] #969980
04/09/11 06:32 PM
04/09/11 06:32 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
HOLY moley. What makes it so expensive? Is it gold plated?
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: $125 for a valve cover gasket?!?!?! [Re: Sixpak] #969981
04/09/11 06:41 PM
04/09/11 06:41 PM
Phila., Pa.
3
344 Offline
super gas
344  Offline
super gas
3
Phila., Pa.
Re: $125 for a valve cover gasket?!?!?! [Re: 344] #969982
04/09/11 07:23 PM
04/09/11 07:23 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Can you just use high temp silicone and forget the gasket?
Re: $125 for a valve cover gasket?!?!?! [Re: Mopar Grandpa] #969983
04/09/11 07:26 PM
04/09/11 07:26 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
125 or even 80 beans ....
It is time that CHINA gets hold of that stamping ...
That is a big gasket ... but not THAT BIG and complex.
Re: $125 for a valve cover gasket?!?!?! [Re: dOc !] #969984
04/09/11 08:08 PM
04/09/11 08:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Is it one of those reusable rubber gaskets? Some of them are very expensive, unlike the cork cheapies.
Re: $125 for a valve cover gasket?!?!?! [Re: DaytonaTurbo] #969985
04/10/11 01:09 AM
04/10/11 01:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Many newer Cummins engines have the injector wire harness made into part of the valve cover gasket. Ron
Re: $125 for a valve cover gasket?!?!?! [Re: 383man] #969986
04/10/11 01:59 AM
04/10/11 01:59 AM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
it is reusable, its silicone and i have pulled off my valve cover and reused the gasket multiple times. no leaks.
Re: $125 for a valve cover gasket?!?!?! [Re: ditchdrift] #969987
04/10/11 06:01 PM
04/10/11 06:01 PM
The Swamp
Sixpak Offline OP
Sixpak  Offline OP
The Swamp
Thanks, will give it a try...and for those that aren't familiar with that gasket, it's a lot like one on a nissan inline 6. It's a big molded gasket, but $125 worth? I don't think so...
Re: $125 for a valve cover gasket?!?!?! [Re: Mopar Grandpa] #969988
04/10/11 10:45 PM
04/10/11 10:45 PM
Phila., Pa.
3
344 Offline
super gas
344  Offline
super gas
3
Phila., Pa.
I never used Permatex Gasket Maker in place of valve cover gasket. I applied RTV Blue with used valve cover gaskets. For $80-$125 gasket, I would try something. I have applied "Permatex Blue" in place of thermostat housing gasket, water pumps and timing covers.
Re: $125 for a valve cover gasket?!?!?! [Re: Sixpak] #969989
04/10/11 10:58 PM
04/10/11 10:58 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
You should be able to reuse it. If not.
http://www.genosgarage.com/prodinfo.asp?number=3935878
Re: $125 for a valve cover gasket?!?!?! [Re: NITROUSN] #969990
04/11/11 01:06 AM
04/11/11 01:06 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
If you can't re-use yours, you might be able to call 10sec440 and ask for his. After the pics he posted, I'd say he's pretty much done using his.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: $125 for a valve cover gasket?!?!?! [Re: NITROUSN] #969991
04/11/11 01:43 AM
04/11/11 01:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
