1995 Stratus lower control change? #969849
04/09/11 12:18 PM
04/09/11 12:18 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
My 95 Stratus needs a right front lower ball joint and lower control arm bushing replaced.
I saw Rock Auto has complete lower arms with bushings and ball joints for about $80.
How difficult are these arms to replace? Can it be done at home without special tools? Will the strut be an issue during the swap?
I appreciate any tips.
Thanks,
Re: 1995 Stratus lower control change? [Re: nd65] #969850
04/09/11 12:42 PM
04/09/11 12:42 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
They are not hard to do,the hardest part will be the sway bar link as long as the bolts are not rusted in.
Re: 1995 Stratus lower control change? [Re: mod381] #969851
04/09/11 02:31 PM
04/09/11 02:31 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Save yourself the head ache and get the new sway bar links while your at it. I don't think I've ever had any come apart without having to cut or use heat.
Re: 1995 Stratus lower control change? [Re: Todd] #969852
04/09/11 06:05 PM
04/09/11 06:05 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Yeah, I was going to do the link to. It looks like there is a front lower and rear lower bolt and the ball joint and sway bar link. Will the strut/spring assembly come into to play at all.
I have removed/installed the control arms on my 65 and this looks doable. I have an impact.
Thanks,
Re: 1995 Stratus lower control change? [Re: nd65] #969853
04/09/11 08:37 PM
04/09/11 08:37 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
No problem/issues with the strut.As long as it's not broken.it has no problem.it is self contained.Also when tightening the rubber control arm bolts.tighten them at/near ride height.Tighten them with arm hanging down,will put extra strain on bushings since they won't be riding @ relaxed stress.Won't have a problem right away,but they could fail prematurely.The strut should not give you anything to be concerned about.
Re: 1995 Stratus lower control change? [Re: moretoys] #969854
04/11/11 09:04 AM
04/11/11 09:04 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thanks guys!!
