Aluminium Intake options with stock manifold locations
#969798
04/09/11 11:40 AM
04/09/11 11:40 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Specifically B Block
all these years I just have seen two intakes with stock locations for some stuff ( like coil )and they are Eddy 2186 ( Performer ) and Holley Street dominator
do you know about any other intake like these ?
whats the importance of these ? coil location is shared in some models to rear AC compressor bracket
if you know more, please post
Re: Aluminium Intake options with stock manifold locations
[Re: JohnRR]
#969800
04/09/11 11:46 AM
04/09/11 11:46 AM
NachoRT74
Valencia, España
yeap, just saw also the Mopar M1, just the choke is diff ( earlier kind inside the crossover ) same as being square bore, will requiere an adaptor for TQ
Lot of manifold have the STOCK "LOCATION" but not the stock indexing, so rear Compressor bracket won't get the hole.
Bien more specific then... also being SPREADBORE if posible LOL ( laters choke mount is too much to ask LOL )
[Re: NachoRT74]
#969801
04/09/11 11:48 AM
04/09/11 11:48 AM
Posts: 74,962 U.S.S.A.
JohnRR
U.S.S.A.
No , what you THINK is a mount for the A/C compressor is not, it's for the coil. I haven't seen any A/C compressor mounts on the aftermarket 4bbls, I don't even think the M1 dual plane has it.
[Re: JohnRR]
#969802
04/09/11 11:50 AM
04/09/11 11:50 AM
NachoRT74
Valencia, España
sorry, edited a little bit the post...
whatever, on lates at least and I think earliers too, the coil and rear AC compresor bracket shares a bolt, the front one
It can't be done on an old D4PB eddy intake for example
[Re: NachoRT74]
#969803
04/09/11 01:43 PM
04/09/11 01:43 PM
Posts: 301 California
court9155
California
You sure about that? I just pulled the A/C setup off a a 67 383 b body and the rear compressor strut used an intake manifold bolt by the driver side exhaust crossover to support it.
67 charger
[Re: court9155]
#969804
04/09/11 05:48 PM
04/09/11 05:48 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
He's correct, C bodies have the same bracket, gets left off with aftermarket manifolds.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: NachoRT74]
#969806
04/10/11 12:19 AM
04/10/11 12:19 AM
NachoRT74
Valencia, España
I did know I had this pic... used for another purpouse, but will work. the bracket on yellow arrow is the one what meets with coil provision
[Re: NachoRT74]
#969807
04/10/11 12:37 AM
04/10/11 12:37 AM
court9155
California
I see. Learn somethin new everyday
67 charger
