dodge magnum problem #969767
04/09/11 09:18 AM
04/09/11 09:18 AM
so cal,cali
calimoparguy Offline OP
so cal,cali
2006 sxt ,I got problem with my tail lights.brake lights work,signals
Work,reverse lights work but when i turn lights on tail lights
Dont come on.......any sugestions where to start look
Re: dodge magnum problem [Re: calimoparguy] #969768
04/09/11 10:06 AM
04/09/11 10:06 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I know this is going to sound funny, but I had the same problem with my wifes jeep. It ended up being the turn signal switch. It pinched a wire from the tilt wheel. Replaced it and it work just fine. Oh and my blinkers and everything worked, but not the running lights. Good luck.
Re: dodge magnum problem [Re: 70dusterjohn] #969769
04/09/11 11:53 PM
04/09/11 11:53 PM
so cal,cali
so cal,cali
well,i looked at the # 8 fuse and it was blown so replaced it with new fuse.lights worked for a bit the fuse blew again??? where should i start???
thanks for any help
Re: dodge magnum problem [Re: calimoparguy] #969770
04/10/11 11:06 AM
04/10/11 11:06 AM
Andrewh Offline
Andrewh  Offline
pull out the tail lights and front running lights and try again.
if it still blows, you have a wiring issue somewhere.
