Oil Leak 70 383 ?????? Update Fixed!!!!!!!!! #969155
04/08/11 08:28 AM
04/08/11 08:28 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
On my RoadRunner every time I drive it any distance there is oil blowed up on the passenger side inner fender well just behind the windshield washer jug. It isn't leaking around the fuel pump. I have every thing like it is suppose to be on the PVC and vents. I have had the valve cover off several times, do you think that it could be coming out around the front of the cover? I just put a new gasket on it and haven't drove it yet. The cover is flat. If this doesn't fix it where should I look. I'm just getting tired of having to clean it every time I drive it. Thanks for any ideals. Ronnie
Re: Oil Leak 70 383 ?????? [Re: okie] #969156
04/08/11 09:21 AM
04/08/11 09:21 AM
dipstick. Might have alot of blowby at WOT
Re: Oil Leak 70 383 ?????? [Re: RapidRobert] #969157
04/08/11 09:24 AM
04/08/11 09:24 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Dipstick is on driver's side, no? If it is the dipstick he should see some trail of oil over to the passenger fender I would think.
Scott
1969 Super Bee, 383/4 speed
Re: Oil Leak 70 383 ?????? [Re: StukaJU87] #969158
04/08/11 09:27 AM
04/08/11 09:27 AM
Wasn't positive as I've been on SB's for decades & am just starting a BB (451)
Re: Oil Leak 70 383 ?????? [Re: RapidRobert] #969159
04/08/11 10:48 AM
04/08/11 10:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That explains why you are batting 1000 answering questions pertaining to big blocks ...
Re: Oil Leak 70 383 ?????? [Re: JohnRR] #969160
04/08/11 01:28 PM
04/08/11 01:28 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I have been back out looking at it and it isn't the timing cover either so it just about has to have been the valve cover. I'm going to drive it again in the morning so I'll see if it is fixed. It makes a mess. Ronnie
Re: Oil Leak 70 383 ?????? [Re: okie] #969161
04/08/11 06:36 PM
04/08/11 06:36 PM
Ronnie holler what it ends up being
Re: Oil Leak 70 383 ?????? [Re: RapidRobert] #969162
04/09/11 06:24 AM
04/09/11 06:24 AM
Poland
W
willard Offline
willard  Offline
W
Poland
do you have a viscotic clutch fan? when mine went away it sprayed the pass inner fender and the hood. check it.
Re: Oil Leak 70 383 ?????? [Re: willard] #969163
04/09/11 07:56 AM
04/09/11 07:56 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
No, I just have a fixed fan on it. Ronnie
Re: Oil Leak 70 383 ?????? Update Fixed!!!! [Re: okie] #969164
04/09/11 10:06 PM
04/09/11 10:06 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Well I put a new gasket on the valve cover, one of the good black coated Fel Pro's and now I have no leak. I got this fixed and on the way home it went to running like crap.It was clattering and wouldn't idle. Does this sound like it got some trash in the carb? Ronnie
Re: Oil Leak 70 383 ?????? Update Fixed!!!! [Re: okie] #969165
04/10/11 01:14 AM
04/10/11 01:14 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Carburetor problems shouldn't make any clatter. That sounds like low oil pressure.
Re: Oil Leak 70 383 ?????? Update Fixed!!!! [Re: Kern Dog] #969166
04/10/11 08:57 AM
04/10/11 08:57 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
This is an all new 383, maybe 800-1000 miles on it. It has always had good oil pressure. My gauge just works when it wants to. After it got past the point of clattering it ran fine untill I got to a lite and I had to keep it idled up just a little and when it did die it would crank right back up. It wasn't running hot. It started all this after I stopped and bought gas. That is the reason I thought it might have got some trash in it. The Edlebrock on it is about 10 years old and I had it on my 340 before I put it on this motor. It has never been apart since I bought it. Any ideals will really help, I have another show this next Sat. so I need to get it straightened out. Thanks Ronnie
