Platinum or Regular plugs in 2005 Hemi?
#968459
04/07/11 02:49 PM
04/07/11 02:49 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
2005 300C w/Hemi 5.7 86k time for a wire and plug change. Thinking of going with Champion #3570 Platinum plugs; I heard the rumors aledging No Platinums in Hemis were unfounded We've had it since 35k and never done anything but regular oil changes, needs an EGR valve too (code pops up only on cold mornings this past winter) gonna change thermostat to and replace rack soon. Anyways, plug thoughts? Thanks!
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Platinum or Regular plugs in 2005 Hemi?
[Re: Challenger 1]
#968462
04/07/11 03:39 PM
04/07/11 03:39 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
When my kid changed the plugs in his 04 he went Champion Platinums.His buddy works at Champion and gave him probally 4 sets.He picked up about 1 MPG and they have been in for 35K now.The OEs he pulled at 26K.Rocky
Chrysler Firepower
[Re: therocks]
#968463
04/07/11 04:30 PM
04/07/11 04:30 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
i use strickly lztr5aix from ngk. or there copper version for the 5.7 hemi.
the 6.1 uses one heat range colder plug btw. from whats stock in a 5.7
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: Hoof Hearted]
#968464
04/07/11 06:38 PM
04/07/11 06:38 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
I have run platinum plugs on a whole bunch of different NA 5.7 vehicles 03 to 08. All ran great.
If you're under warranty, run the OE stuff so nobody will question it.
If not (or you just don't care about warranty) you won't go wrong with platinums.
A guru had spoken long ago and had told me to never use platinum plugs on 5.7s, ever. When asked "why can't I use platinums on a 2006 5.7 (which has the same coils as a 6.1, and why did the 6.1 have platinum plugs all along if platinums are so bad)?".....no answer....which at that point was a good clue to just use whatever and don't worry about it.
Am I enamoured with platinum or other exotic material plugs? heck no. For some cars they aren't worth it, and they cause alot of misfires on supercharged or other boosted applications. Then there are cars like my GTX which doesn't get enough miles put on it to wear out copper core/normal cheap plugs, so why bother with anything else.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#968465
04/07/11 06:52 PM
04/07/11 06:52 PM
gremlinsteve
houston texas
and another note. with as many of these cars as i have worked on i have seen ngk plugs stock in them. heck, if you buy heads from moapr now the eagles use a ngk plug. there platinum also.
that number i listed was for a iridium set
steve
[Re: gremlinsteve]
#968466
04/07/11 07:14 PM
04/07/11 07:14 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
What does the owner's manual say to use??
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#968467
04/07/11 07:28 PM
04/07/11 07:28 PM
gremlinsteve
houston texas
never looked. i always used the ngk. i found that they idle better. but again, these where not really stock cars.
steve
