fixing stripped hole for exhaust stud in a 452 head #968009
04/06/11 08:26 PM
04/06/11 08:26 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The last time I messed with the hot rod it had a stripped hole for an exhaust stud. Since these holes are wet what's the best way to fix it?
Will a heli coil provide a watertight seal under radiator pressure or should I look at doing something else?
- Stu Harmon
Re: fixing stripped hole for exhaust stud in a 452 head [Re: feets] #968010
04/06/11 08:39 PM
04/06/11 08:39 PM
yes it will
Re: fixing stripped hole for exhaust stud in a 452 head [Re: feets] #968011
04/06/11 08:39 PM
04/06/11 08:39 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
it should if you use sealer or maybe even some j/b on it. That or you can re-tap it to the next size up metric. I'd drill it, tap it, run the sealer all over the coil, set the coil, let it set-up then run your stud/header bolt in as usual. I hope it's off the car.
Coming soon!!!!
Re: fixing stripped hole for exhaust stud in a 452 head [Re: feets] #968012
04/06/11 08:58 PM
04/06/11 08:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Should be no problem with a heli coil.
Re: fixing stripped hole for exhaust stud in a 452 head [Re: Mr.Yuck] #968013
04/06/11 09:00 PM
04/06/11 09:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I will be different but I would tap it out to the next over size and use a step stud. That way there is only one potential leak spot to seal rather than 2.
Re: fixing stripped hole for exhaust stud in a 452 head [Re: MoparforLife] #968014
04/06/11 10:31 PM
04/06/11 10:31 PM
Visalia Ca
P
prostreet68 Offline
prostreet68  Offline
P
Visalia Ca
One of the guys over on BBD used a threaded insert that he got from Grangers. He said that he didnt like the heli coils. With the threaded insert he used an epoxy. There was never an issue with coolant leakage.
Re: fixing stripped hole for exhaust stud in a 452 head [Re: prostreet68] #968015
04/06/11 10:59 PM
04/06/11 10:59 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We had our max wedge heads repaired with time-serts. Threads can be sealed and top part of insert is tapered and seals well to the block. Much better than heli-coils.
Time sert
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
