Platinum Plugs (all they had); what to gap? #966701
04/05/11 10:25 AM
04/05/11 10:25 AM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
So I went to the parts store to buy plugs for my 440ci edelbrock headed motor in my c-body. Motor is occassionally sprayed 150, and I use an MSD ignition with a blaster 2 coil and good plug wires (ignition system is good).
Plugs on my old NGK split-fires were gapped .50. All they had this time in stock were platinum plugs. I've 'heard' that they should be gapped further out since they require less voltage, and gapping them the same will result in less spark. Any advice/experience?
Re: Platinum Plugs (all they had); what to gap? [Re: charger] #966702
04/05/11 10:47 AM
04/05/11 10:47 AM
Under My Car
Mopar_Country Offline
Under My Car
I don't think you want to use platinum plugs if your spraying. Nitrous can cause damage to the plugs and you may end up with small particles in the cylinders. I've also read they can cause intake manifold explosions. If you run em, keep your finger off the button.
Re: Platinum Plugs (all they had); what to gap? [Re: Mopar_Country] #966703
04/05/11 01:26 PM
04/05/11 01:26 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Platinum plugs are a harder plug and not as easy to light off. A big no-no in boosted applications, so I would ASSume a no-no with spray. I wait to be corrected if I'm wrong.
Re: Platinum Plugs (all they had); what to gap? [Re: charger] #966704
04/05/11 01:55 PM
04/05/11 01:55 PM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
....great, guess I'll be returning these. Hope they take them back.
Re: Platinum Plugs (all they had); what to gap? [Re: charger] #966705
04/05/11 03:35 PM
04/05/11 03:35 PM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
ok, got a set of TR5-1 018-3640-8
NGK V-Power; are these ok? If so what should I gap them at?
Re: Platinum Plugs (all they had); what to gap? [Re: charger] #966706
04/05/11 03:50 PM
04/05/11 03:50 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
With the MSD, I'd gap them at .050.
Re: Platinum Plugs (all they had); what to gap? [Re: DusterKrazy] #966707
04/05/11 04:05 PM
04/05/11 04:05 PM
Regina, SK, Canada
charger Offline OP
charger  Offline OP
Regina, SK, Canada
is this an ok plug to run? I'm spraying about 150, most of the time driving regularly.
