Re: Transmission leak
[Re: Commando1]
#965788
04/05/11 10:33 AM
04/05/11 10:33 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
It's a flat paper gasket, this is the reverse detent .... BE CAREFUL , put the trans in reverse first, remove the top nut first , pull out the spring and fish out the steel ball or else it will fall intothe trans when you pull out the holder. What's that red carp drooling down the side ??? don't say ATF ... Are you this thing yet ?
[Re: JohnRR]
#965790
04/05/11 12:58 PM
04/05/11 12:58 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Thank you. I would NOT have known that.
Ummm.. OK, I won't say it then...
Seriously, I initially filled it w/ATF specifically to sniff out any leaks (which it did). 90 weight gear is going in.
Yep, on the road again. Drives and shifts like a dream.
