2010 chllenger traction controll #964606
04/02/11 06:49 PM
04/02/11 06:49 PM
LA CA
bron_engines Offline OP
LA CA
Yep, that sucks. spend 32K on a 2010 challenger 6spd and the car will not burn any rubber. I read that if you have the car in a forward gear hold down the traction controll button until the light goes out that is supposed to disengage the traction controll.
That only raises the limiting point a few hundred RPM. I can pop the clutch in the car wash at 6 thousand and it will not burn rubber. The only way I can beat a dumb mustang is to get him from a roll.
Re: 2010 chllenger traction controll [Re: bron_engines] #964607
04/02/11 11:00 PM
04/02/11 11:00 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: 2010 chllenger traction controll [Re: bron_engines] #964608
04/03/11 08:34 PM
04/03/11 08:34 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I have a 2010 SRT 8 6 speed Challenger and it will do awesome burn outs! Push the ESP button down and hold. After 3 seconds the stability portion is deactivated and after 8-10 seconds the traction control is deactivated. Happy burn outs to you! PS mine is a trac-pack with 3.92 gears.
Re: 2010 chllenger traction controll [Re: mercman1] #964609
04/03/11 08:45 PM
04/03/11 08:45 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
That's WHY I bought the 6 speed tracpac car. Complete disabling of the nanny controls.
Re: 2010 chllenger traction controll [Re: DennisH ] #964610
04/08/11 12:36 AM
04/08/11 12:36 AM
LA CA
LA CA
SRT 8 will burn out. I love those cars but ten grand more WOW. There has to be a way to turn the dumb traction controll off.
Re: 2010 chllenger traction controll [Re: bron_engines] #964611
04/08/11 01:19 AM
04/08/11 01:19 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I have one of these in my srt300 and my srt caliber....
http://www.aeroforcetech.com/products_interceptor.html
They can completely turn off the ESP and they enable you to monitor a ton of different functions. I've found them useful.
Re: 2010 chllenger traction controll [Re: POS Dakota] #964612
04/09/11 09:40 PM
04/09/11 09:40 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
You dont need an SRT, or buy anything to add to you car to get it to do a good burnout. There is a little trick called the "key trick".
What this means is while going at least 10 mph, turn and hold the key like you are trying to start the car. Dont worry, the starter wont engage. Hold the key until you see the esp light and the bas light come on, then release the key. This completely disables the traction control and the auto braking system. It only works until you turn off the car, then everything resets.
After you do this, burn away!
Re: 2010 chllenger traction controll [Re: moparguy7074] #964613
04/10/11 09:44 AM
04/10/11 09:44 AM
LA CA
LA CA
Thanks I will try it this morning and let you know if it works. If it does there is a guy down the street with an 08 mustang that I have been avoiding until I can get this figured out.
Re: 2010 chllenger traction controll [Re: bron_engines] #964614
04/10/11 11:45 AM
04/10/11 11:45 AM
Rudolph, Ohio
Rudolph, Ohio
I do this same trick with my 2010 quite often. And it doesnt take revvin it up to 6k to get them spinning either.
Re: 2010 chllenger traction controll [Re: moparguy7074] #964615
04/10/11 10:58 PM
04/10/11 10:58 PM
LA CA
LA CA
Well the trick works once then you have to turn it off again to continue to have fun but now the engine light is on. I am getting bummed out.
Re: 2010 chllenger traction controll [Re: bron_engines] #964616
04/10/11 11:01 PM
04/10/11 11:01 PM
LA CA
LA CA
when I hold the key button the car goes dead, then I have to push the button again for the power to come back on. I give up!! I will resort to my big block dart to have fun and the challenger to take the wife to dinner.
