70 RR ,no dash lights #964221
04/02/11 09:40 AM
04/02/11 09:40 AM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Lost my dash lights last night.They worked last year.Could it be the dimmer???Seemed they went out once last year and it was something stupid,but I cant remember what I did.THANKS
Re: 70 RR ,no dash lights [Re: 70RR383] #964222
04/02/11 09:42 AM
04/02/11 09:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Could be the dimmer , easy to check. Turn it to the full on position , the spot just shy of turning on the interior lights , if the dash lights come on them the resistor wired has burned thru , common problem . If not check the fuse .
Re: 70 RR ,no dash lights [Re: JohnRR] #964223
04/02/11 10:06 AM
04/02/11 10:06 AM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
I read your post,if they come on,then I dont have the problem.Do you meen if they DONT come on??
Re: 70 RR ,no dash lights [Re: 70RR383] #964224
04/02/11 10:28 AM
04/02/11 10:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , if they come on you need a new dimmer switch because the dimmer part is burnt out ... assuming you want that function to continue to work .
