King pin dia. and length? #963985
04/01/11 09:43 PM
04/01/11 09:43 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
I know these are ford parts but want the look.
What is the dia. of the king pin on 42-48 axle
And what is the dia. of a 58 F100 front axle?
Thanks Kurt
Re: King pin dia. and length? [Re: kams] #963986
04/02/11 09:05 AM
04/02/11 09:05 AM
moparx Offline
moparx  Offline
42-48 pin size is : .813 and the pin length is 6". thats the "standard" pin used on most streetrod front axles. the only info i can give you on the 58 f100 axle is the pins are listed as different part #'s for : 48-52, 53-56, and 57-64 1/2 ton[f-1, f100]. hope this helps some.
