Re: sliding around corners possible with TrueTrack?
[Re: kielbasa]
#963946
04/01/11 08:20 PM
04/01/11 08:20 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: 5spdcuda]
#963949
04/01/11 08:45 PM
04/01/11 08:45 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Driver inputs & the overall balance/grip of the car will probably have more to do with how much slipping and sliding takes place than the type of limited slip used. IMO no limited slip can fully control a high torque engine with any true street tire. I've got a pretty small & ordinary engine and getting the power down on corner exit is still a balancing act on low to medium speed corners. FWIW I am using a plate type Sure Grip with really good lock up, 3:55 gears and 245x45x17 Kumho SPT's.
I agree. Hanging-tail as we used to call-it, has more to do with the driver's right foot than any other factor, assuming the car HAS a limited slip, and enough grunt to overpower the tires.
[Re: kielbasa]
#963951
04/01/11 11:02 PM
04/01/11 11:02 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
What they are telling you is under normal driving the axles are able to rotate at different speeds without forcing a clutch to slip so it acts like an open axle... but under power it will hang the tail just fine...
[Re: kielbasa]
#963952
04/01/11 11:14 PM
04/01/11 11:14 PM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Hi guys, wondering if anyone here has experience with a truetrack (gear type) limited slip..... will be installing S60 into my car, but wondering if I should go with std clutch type or upgrade to truetrac? I REALLY like to slide my cuda around corners, but am wondering if the trutrac would make that a lot harder to do?? Thanks for any input!!
Any traction locking unit will help you spin both wheels at an equal speed and spin you around smoothly. I ran the gear style and for the most part found it useless. It may work well when bothe wheels are on a good surface.
