Source for replacement HVAC controls? 71 plymouth
#963762
04/01/11 03:07 PM
04/01/11 03:07 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
The HVAC controls for my valiant are in pretty bad shape. The plastic case is cracked and melted around one of the terminals, and has some other issues as well. This is a factory A/C car. Does anyone know where to get a replacement? Is a junkyard the only option? I attached a picture to show which style I'm talking about.
Thanks! -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: Source for replacement HVAC controls? 71 plymouth
[Re: blown340]
#963764
04/02/11 12:58 PM
04/02/11 12:58 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
I think you are talking about the plastic control behind the buttons on the front. It is seperate part from the actual buttons you push on the front side . . . this plastic part is the vaccum control and electrical control. I believe this part was used on a bodies, b bodies, c bodies, etc. . . . you need to get the part number and do a search for that - it has been on ebay for long time. Do a search and see if you find the part on the web somewhere . . . Check out these ebay listings . . . as you can see, the unit is mounted behind the actuator buttons - should be same unit as yours . . . http://cgi.ebay.com/ebaymotors/1970-Chry...=item1c1a961757http://cgi.ebay.com/ebaymotors/Airtex-1S...=item2eb38104daCheers Mark
[Re: a12rag]
#963765
04/02/11 03:39 PM
04/02/11 03:39 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
it will be a module unit, might have electrical and vacuum controls.....most of them if original have a oem # stamped in red or black on it....give me that and i will look at the ones i have .....
[Re: blown340]
#963768
04/03/11 12:36 AM
04/03/11 12:36 AM
blown340
Walnut Creek, CA
Thanks for the responses everyone, here are a few pictures of mine. As you can see the terminal is broken off on the one side and the case is cracked and slightly melted. Fortunately the wiring problem that caused this, and destroyed the rest of the underdash harness has been fixed.
Any leads on a replacement part are much appreciated! The numbers on it appear to be 3502126B and 2357.
Pic 1/4
Thanks, -Jon
[Re: blown340]
#963774
04/03/11 05:00 PM
04/03/11 05:00 PM
Posts: 233 WV,USA
wvmarv
WV,USA
Thanks! -Jon
My local parts store can special order for you. here's the link. http://www.autozone.com/autozone/parts/D...r=68558_0_3319_
[Re: wvmarv]
#963775
04/03/11 07:22 PM
04/03/11 07:22 PM
blown340
Walnut Creek, CA
The vacuum switch itself is still available for a number of applications as an over the counter item at many parts stores. I looked one up recently for a C-body. For example, here's one for a '72 Valiant on Rock Auto: http://www.rockauto.com/catalog/moreinfo.php?pk=933374
Awesome, thank you! I had tried searching my local auto store, but they couldn't figure out what to look up.
Thanks again, -Jon
