Carb "air screen" for track-only use? #962970
03/31/11 11:18 AM
03/31/11 11:18 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Anybody seen or used these? http://www.jegs.com/p/TICU-Racing/TICU-Racing-Full-Flow-Air-Screen/1566809/10002/-1
I'm wondering whether something like that would prove effective enough for track-only use (i.e. swap from regular air cleaner to this w/ a plate attached to seal the screen to the scoop) to provide some additional space between the carb and hood and free up my options for intakes to run w/ the Victor heads. Considering I've been using a 3" drop-base air cleaner, it's also not clear how much actual space above the carb this would add in comparison.
I really don't like the idea of running w/ no air filtration system at all on the track. However, I'm not sure how much this will do beside stopping birds, wayward children, rocks kicked up by cars ahead of me in the burnout box, etc. Maybe that's enough for just making passes down the 1320.
Oh, I also think they're HORRIBLY expensive for what they are.
Re: Carb "air screen" for track-only use? [Re: BradH] #962971
03/31/11 11:37 AM
03/31/11 11:37 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I think mine will work just as well as those and they are a lots cheaper. I got 2 radio speaker grills(got Lucky and found some metal ones)to run on mine.They come in all sizes,just drill a hole in the middle and bolt them down. Check mine out & see what you think.
PS The man at the stereo shop down the road give me mine. Most stereo shops have some laying around or can order you most any size you need.
""CHEAP""
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Carb "air screen" for track-only use? [Re: BradH] #962972
03/31/11 11:39 AM
03/31/11 11:39 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
There is a reason for a air filter, it's to filter air. A buddy of mine bought one of those air screens, as you said , pretty expensive , they look trick, will screen out the rocks and smaller debree. The piece sets about 4" high , he cut about a 1" off the bottom of his to gain some hood clearance, was a waste of money as he went back to the K&N filter. If you have carb/hood issues now I wouldn't recommend it.
Re: Carb "air screen" for track-only use? [Re: rowin4] #962973
03/31/11 11:51 AM
03/31/11 11:51 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Mine only set about a 1/2" high. If you notice mine does not set on the carb.(injector on mine)flange. The scoop tray stills sets on the carb. flange so there is no added height.
I may be wrong but in my 20+ years of racing I have never used or saw the need for a filter on a Race-Car. Any kind of filter at all would hurt the air flow,hurt the hurt air flow kill the HP.
On a street/strip car Yes I see a need for one.
Re: Carb "air screen" for track-only use? [Re: rowin4] #962974
03/31/11 12:55 PM
03/31/11 12:55 PM
organ
maximum entropy Offline
organ
100%
i am the air filter nazi on account of what i see when i tear down engines that run without air filters. also, consider the carburetor. a precision metering device with exposed orifices, and you're going to leave it exposed to an unfiltered airstream? i see it at the track all the time. "my car ain't idling right. can you come touch the carburetor?" well, loogathere, IT AIN'T GOT NO AIR FILTER ON IT! airbleeds are all crudded up. airhorn looks like someone poured sand in it. lunacy.
Re: Carb "air screen" for track-only use? [Re: MRMOPAR622] #962975
03/31/11 12:56 PM
03/31/11 12:56 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have been thinking about this myself,the opening in the SV1 carb is very large.When I saw one of these in the kitchen,it clicked!!I will end up with a pair of these for when I remove the big K&N's
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Carb "air screen" for track-only use? [Re: hemi-itis] #962976
03/31/11 01:06 PM
03/31/11 01:06 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I think it was Chevrolet that used a mesh " diffuser " above the carb and inside the air filter.
The logic was to straighten out the air flow or reduce turbulence or some such.
I have seen pictures and I believe they only did it on H.P. big blocks.
But their engineers thought the idea had merit obviously.
I don't think the gains of running without a filter are worth the shortfalls.
Now , a restrictive system is another story.
I see a lot of tunnel ram set ups with two tiny filters on them and have to scratch my head.
But with quality components , I don't think the power loss is enough to lose sleep over.
That being said , I don't run pro stock.
There are applications where they do hurt performance enough to matter.
But for a street / strip car , I'll always use one.
Re: Carb "air screen" for track-only use? [Re: tubtar] #962977
03/31/11 01:13 PM
03/31/11 01:13 PM
hemi-itis Offline
hemi-itis  Offline
tubtar,I hear what your saying.I will wait untill I get my junk consistant enough to try the screen to see if it's worth using at all
Re: Carb "air screen" for track-only use? [Re: tubtar] #962978
03/31/11 01:15 PM
03/31/11 01:15 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Carb "air screen" for track-only use? [Re: Hemi Allstate] #962979
03/31/11 01:22 PM
03/31/11 01:22 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
That is a picture of corvette with the L88. I also read that racers found a performance increase by removing the mesh filter.
Getting old just means you were smarter than some and luckier than others.
Re: Carb "air screen" for track-only use? [Re: Hemi Allstate] #962980
03/31/11 01:26 PM
03/31/11 01:26 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If you thought those were expensive, you should see the price of the Mopar Performance ones...
Summit
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Carb "air screen" for track-only use? [Re: dannysbee] #962981
03/31/11 01:27 PM
03/31/11 01:27 PM
Mt. Eden Ky.
Mt. Eden Ky.
You are correct! It belonged to a friend of mine. Actually a ZL 1 in the picture.
1996 Ram 1500 Sport
1968 road runner
Re: Carb "air screen" for track-only use? [Re: BradH] #962982
03/31/11 01:29 PM
03/31/11 01:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
4404dart had one.
I have something like that on my SV1...
Mopar Performance
Re: Carb "air screen" for track-only use? [Re: moparniac] #962983
03/31/11 07:39 PM
03/31/11 07:39 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
made this one myself about 35.00
Re: Carb "air screen" for track-only use? [Re: MOPARCHAS] #962984
03/31/11 07:40 PM
03/31/11 07:40 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
another angle
Re: Carb "air screen" for track-only use? [Re: Dads426] #962985
03/31/11 08:23 PM
03/31/11 08:23 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Summit
hey whatta u mean,mopar only asks 630+ bucks for air horns! i nearly fell off the chair when my bud typed it in on the dealers computer
Re: Carb "air screen" for track-only use? [Re: fishy340] #962986
03/31/11 08:25 PM
03/31/11 08:25 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
find a dollar store they have them in there...for .....a dollar
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Carb "air screen" for track-only use? [Re: MOPARCHAS] #962987
03/31/11 08:38 PM
03/31/11 08:38 PM
MOPARCHAS
Where did you get the bases from?
Very nice job you did.
Re: Carb "air screen" for track-only use? [Re: Dads426] #962988
03/31/11 08:48 PM
03/31/11 08:48 PM
Idaho
Runner Offline
Runner  Offline
Idaho
Summit
thats funny stuff. i wonder, has anyone ever purchased those?
Re: Carb "air screen" for track-only use? [Re: Runner] #962989
03/31/11 09:50 PM
03/31/11 09:50 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Sure, just go on ebay and look up (Plymouth, Dodge) Max Wedge and see all those $250,000 trailer queens for sale.
