Paint curing - Air dry vs heat lamps #962743
03/30/11 10:18 PM
03/30/11 10:18 PM
Eagle, Idaho
Neil Online content OP
The Doctor is in.
Neil  Online Content OP
The Doctor is in.
Eagle, Idaho
Does curing urethane paint with lamps help make the paint any more durable, or is the only benefit faster drying times for production purposes?
I have a set of steel mopar wheels that need painted body color on the outside and was curious if it's worth it to pay a shop to bake them or just let them cure on their own.
Re: Paint curing - Air dry vs heat lamps [Re: Neil] #962744
03/30/11 10:48 PM
03/30/11 10:48 PM
IN
ahy Offline
ahy  Offline
IN
Time and a couple sunny Idaho days should cure it well. The lamps will just speed the process I think. Urethane (two part I assume) gets hard pretty fast so it shouldn't be excessivly tender after 2-3 days of air curing.
Re: Paint curing - Air dry vs heat lamps [Re: Neil] #962745
03/31/11 12:00 AM
03/31/11 12:00 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
Baking the paint will actually make it die back and not look as glassy. It is better to always let it dry naturally when you can. It will harden the same either way. I am a master painter and painting is my job. When I paint a car at the end of the day. I will let it air dry overnight. Alot nicer results. Baking paint is only for production purposes. So you can paint multiple cars in a day ,instead of just one.
Re: Paint curing - Air dry vs heat lamps [Re: keith airgrabber] #962746
03/31/11 12:03 AM
03/31/11 12:03 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Urethanes dry by 2 different methods. One is solvent evaporation and the other is cross-linking of the catalyzed components. Baking is purely for production. A few sunny warm days will do the trick.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Paint curing - Air dry vs heat lamps [Re: keith airgrabber] #962747
03/31/11 12:06 AM
03/31/11 12:06 AM
Eagle, Idaho
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Thanks for the replies.
I'll just paint them myself when it warms up enough. We are in the 50's and 60's, but it keeps getting cloudy and raining every other day. As soon as we get a warm and dry streak going I'll give it a shot.
Re: Paint curing - Air dry vs heat lamps [Re: keith airgrabber] #962748
03/31/11 12:07 AM
03/31/11 12:07 AM
I am a master painter Baking paint is only for production purposes.
Ahhh I always thought the bulbs in a paint booth were to harden the paint & obviously they would dry it faster. Deciding whether to try barbeque grill paint or have some headers chromed. Not so concerned about looks as I am about staving off them rusting out
Re: Paint curing - Air dry vs heat lamps [Re: RapidRobert] #962749
03/31/11 12:59 AM
03/31/11 12:59 AM
hooziewhatsit Offline
All that being said, I've baked a few things now, and they turned out much better than they would air drying. Granted, it is winter, so it would otherwise take a couple weeks to cure
Hopefully my future garage will have room for a $20 craiglist oven so I can bake things and have them done now.
Re: Paint curing - Air dry vs heat lamps [Re: Neil] #962750
03/31/11 01:02 AM
03/31/11 01:02 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Must........resist.........
Re: Paint curing - Air dry vs heat lamps [Re: Neil] #962751
03/31/11 01:48 AM
03/31/11 01:48 AM
Jacksonville Florida
elitecustombody Offline
Just paint and let them air dry, cooking paint won't make it any more durable
Re: Paint curing - Air dry vs heat lamps [Re: elitecustombody] #962752
03/31/11 01:56 AM
03/31/11 01:56 AM
got it and that concept had been entrenched in my brain for decades
