What size diameter carb holes in max wedge hood? #96148
07/28/08 04:39 PM
07/28/08 04:39 PM
West Central Florida
doncarson Offline OP
Hi;
My MW clone is almost complete and I need to know what is the factory size diameter holes to cut for the carb to scoop?
My body shop is waiting for me to let him know.
Thanks in advance!
Don
Re: What size diameter carb holes in max wedge hood? [Re: doncarson] #96149
07/29/08 05:06 AM
07/29/08 05:06 AM
IN
polaraholic Offline
polaraholic  Offline
IN
I'd like to know also. A template that you could place on the hood would be great. If anyone has a MW car here's your chance to make some $$$ here or ebay.
Re: What size diameter carb holes in max wedge hood? [Re: polaraholic] #96150
07/30/08 09:12 PM
07/30/08 09:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sorry I cant help as I would like to know also. Ron
Re: What size diameter carb holes in max wedge hood? [Re: 383man] #96151
07/30/08 10:26 PM
07/30/08 10:26 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
5" diameter is what two of my buddies found out for their Max Wedge recreations.
On my buddy's car, we put a thick diameter of modeling clay on the underside of the hood, then installed a short stud into the carb and carefully closed the hood until it made and impression in the clay. Do this individually for each carb. Then we drilled a 1/4" pilot hole at the stud location. I machined an 1/8" thick disc 5" in diameter with a 1/4" diameter pilot hole and used it as a template to scribe a line around.
Re: What size diameter carb holes in max wedge hood? [Re: Dave Watt] #96152
07/31/08 12:29 AM
07/31/08 12:29 AM
IN
polaraholic Offline
polaraholic  Offline
IN
Did you have to go through any of the bracing?
Re: What size diameter carb holes in max wedge hood? [Re: polaraholic] #96153
07/31/08 07:14 AM
07/31/08 07:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
On an original hood the center bracing is removed.
Re: What size diameter carb holes in max wedge hood? [Re: polaraholic] #96154
07/31/08 09:26 AM
07/31/08 09:26 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Yes, we removed the bracing just like the originals.
Re: What size diameter carb holes in max wedge hood? [Re: Dave Watt] #96155
07/31/08 12:26 PM
07/31/08 12:26 PM
I would guess that Scottsmith@Harms has some of this info. Haven't seen him on the board in the last few days though...
Here's a pic of the bracing removed:
Re: What size diameter carb holes in max wedge hood? [Re: doncarson] #96156
07/31/08 12:51 PM
07/31/08 12:51 PM
CrazyD Offline
CrazyD  Offline
I believe 'Hemieddie' on ebay sells a template
