MOOG upper control arm bushings #959714
03/27/11 09:31 AM
03/27/11 09:31 AM
Maryland
cudaboone Offline OP
Maryland
Anyone here use the moog offset upper control arm bushings. What would keep them from rotating after installation and making the problem worse?
Re: MOOG upper control arm bushings [Re: cudaboone] #959715
03/27/11 10:04 AM
03/27/11 10:04 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They are pressed in like the originals.The hole is offset in the rubber.They also dont get installed like the instructions say.they go in opposite.Rocky
Chrysler Firepower
Re: MOOG upper control arm bushings [Re: therocks] #959716
03/27/11 10:08 AM
03/27/11 10:08 AM
Maryland
Maryland
Would they have to be tack welded in the desired position so that they will not move or will they not rotate any once installed? I need to get about 2 more degrees according to the guy who did my alignment.
Re: MOOG upper control arm bushings [Re: cudaboone] #959717
03/27/11 10:29 AM
03/27/11 10:29 AM
If they press in real tight & most do they will not move. & remind your alignment guy to tighten the UCA cam bolt nuts TIGHT when he's done
Re: MOOG upper control arm bushings [Re: RapidRobert] #959718
03/27/11 10:33 AM
03/27/11 10:33 AM
Maryland
Maryland
Thanks guys. summit them for under 50.00 for both sets.
Re: MOOG upper control arm bushings [Re: cudaboone] #959719
03/27/11 01:19 PM
03/27/11 01:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
These were in my car for 17 years 1994-2010 and about 80K miles. Still look fine.
Use these instructions...
