I need help finding header studs... #959566
03/27/11 12:03 AM
03/27/11 12:03 AM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I don't know if I don't know what I am looking for or what but I need a source to find some header studs. I have stealth heads on my 440.
I know the head side of the stud needs to be
3/8 X 16. It seems there is about 3/4 of a inch of thread internally(in Head). I WANT to use all that correct? All I can find is bolts which I don't want to use or the studs I do find seem to be way to short.
Can anyone help me out here. Install is next weekend and I hate to put it off for something this trivial!!
THNX!!! Chuck
Re: I need help finding header studs... [Re: moparrulzzz] #959567
03/27/11 12:22 AM
03/27/11 12:22 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Studs dont always work the best with headers. Why not use bolts?
Re: I need help finding header studs... [Re: NITROUSN] #959568
03/27/11 01:24 AM
03/27/11 01:24 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
And fine thread on the header side. My local hardware stores stock them. The even have some with allen recesses in them. Or there's always McMaster-Carr. Or your favorite restoration parts supplier, if stock length is fine.
Use as many studs as possible (check tube interference) in aluminum heads. And thread sealant.
Re: I need help finding header studs... [Re: NITROUSN] #959569
03/27/11 01:33 AM
03/27/11 01:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: I need help finding header studs... [Re: 1_WILD_RT] #959570
03/27/11 03:45 AM
03/27/11 03:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I believe that there is a general rule for fasteners:
The thread engagement of a fastener should be equal to or greater that its diameter/width. A 3/8 bolt should engage the threaded hole a minimum of 3/8 of an inch.
Its the same with lug nuts, at least thats been my own practice.
Re: I need help finding header studs... [Re: Kern Dog] #959571
03/27/11 10:18 AM
03/27/11 10:18 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I just used set screws in my alu. heads. You can get them in most lengths and you have the benefit of being able to use an allen wrench to install them. I think i used 2 inch in mine, that way i can use all the head threads plus gasket thickness plus 1/2 header flanges plus another 1/2 or so for a lock washer and nut.Just be sure to use some anti-sieze on them. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: I need help finding header studs... [Re: rattler] #959572
03/27/11 10:38 AM
03/27/11 10:38 AM
the shouldered OE type studs by far seal the best (sealer on the coarse thread section) and can trim the outer fine threaded section till you only have enough left (mockup/measure/cut) for a thin high grade nut to fit flush as any more is a waste & hampers header fit
Re: I need help finding header studs... [Re: NITROUSN] #959573
03/27/11 12:01 PM
03/27/11 12:01 PM
Mansfield,Ohio
Mansfield,Ohio
I guess I have always been told to go with studs, also scared to death I will over tighten them.
Re: I need help finding header studs... [Re: rattler] #959574
03/27/11 02:58 PM
03/27/11 02:58 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Maybe not as easy if headers need to come out if the engine is in the car, but full engagement in the heads is guaranteed... E-heads here.
Mine are from www.tacomascrew.com, it was local for me, but I believe they ship also.
A search on set screws turned this up...
http://www.tacomascrew.com/products/search/set%20screw
Re: I need help finding header studs... [Re: MoparMarq] #959575
03/27/11 04:26 PM
03/27/11 04:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Bolts can be pretty lousy sometimes, but I have put on some headers where the tube is so close to where the stud would be that you'd have to feed the nut on as you slide the headers down the stud. Would make in-car R&R a huge pain. Really depends on the header design IMO.
Re: I need help finding header studs... [Re: DaytonaTurbo] #959576
03/27/11 06:31 PM
03/27/11 06:31 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i say just go with a set of header bolts, your alum heads have all blind holes so just use anti-sieze and you're good, much easier to install and remove than studs
Re: I need help finding header studs... [Re: dirtybee] #959577
03/27/11 07:41 PM
03/27/11 07:41 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Studs are great if there's clearance to get the headers on and off, there usaully isn't.
The next best choice like what was mentioned is 12 point header bolts that are long enough. A lot of header bolts I have seen are too short, I don't know why, maybe for cheaper,thinner headers?
Reg hex head bolts won't work most of the time.
A auto part store that sell's Dorman can get you the correct size studs, you need to know what size you need though.
Re: I need help finding header studs... [Re: moparrulzzz] #959578
03/27/11 08:23 PM
03/27/11 08:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
These are header bolts, I don't remember were I got em. But they are too short at .750" long. Even with cheap headers I don't feel there long enough. No way they would work with thick TTI header flanges. They need to be 1.00" long, header bolts.
