I need help finding header studs...
#959566
03/27/11 12:03 AM
03/27/11 12:03 AM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
I don't know if I don't know what I am looking for or what but I need a source to find some header studs. I have stealth heads on my 440. I know the head side of the stud needs to be 3/8 X 16. It seems there is about 3/4 of a inch of thread internally(in Head). I WANT to use all that correct? All I can find is bolts which I don't want to use or the studs I do find seem to be way to short. Can anyone help me out here. Install is next weekend and I hate to put it off for something this trivial!! THNX!!! Chuck
Re: I need help finding header studs...
[Re: rattler]
#959572
03/27/11 10:38 AM
03/27/11 10:38 AM
RapidRobert
the shouldered OE type studs by far seal the best (sealer on the coarse thread section) and can trim the outer fine threaded section till you only have enough left (mockup/measure/cut) for a thin high grade nut to fit flush as any more is a waste & hampers header fit
[Re: NITROUSN]
#959573
03/27/11 12:01 PM
03/27/11 12:01 PM
moparrulzzz
Mansfield,Ohio
Studs dont always work the best with headers. Why not use bolts?
I guess I have always been told to go with studs, also scared to death I will over tighten them.
[Re: rattler]
#959574
03/27/11 02:58 PM
03/27/11 02:58 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I just used set screws in my alu. heads. You can get them in most lengths and you have the benefit of being able to use an allen wrench to install them. I think i used 2 inch in mine, that way i can use all the head threads plus gasket thickness plus 1/2 header flanges plus another 1/2 or so for a lock washer and nut.Just be sure to use some anti-sieze on them. Randy
Maybe not as easy if headers need to come out if the engine is in the car, but full engagement in the heads is guaranteed... E-heads here.
Mine are from www.tacomascrew.com, it was local for me, but I believe they ship also.
A search on set screws turned this up...
http://www.tacomascrew.com/products/search/set%20screw
