Comp cams 925-16 springs, good choice? #959552
03/26/11 11:31 PM
03/26/11 11:31 PM
RapidRobert Offline OP
Daily driver BB w stock(ish)cam. Found these for a good price, is this too much spring for my app? Dual sp w dampener 395 lbs. Thank you for your time.
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959553
03/26/11 11:48 PM
03/26/11 11:48 PM
IN
ahy Offline
ahy  Offline
IN
If you have stout rockers and pushrods they will work and last... just a bit overkill and will put more stress on the cam/lifter/valvatrain than necessary. I would guess they will hurt stock stamped rockers. Sometimes shops like Hughes have "take off" springs from Ed or 440 source heads at low cost. That may be another choice... or a new single spring at about $6 each.
Re: Comp cams 925-16 springs, good choice? [Re: ahy] #959554
03/26/11 11:53 PM
03/26/11 11:53 PM
Thanks Ahy, I'll get on it & find a better choice
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959555
03/27/11 12:03 AM
03/27/11 12:03 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Did you check the specs on a stock spring? I dont have a manual here but they may not be to far off. The closed seat pressure is about 110.
Re: Comp cams 925-16 springs, good choice? [Re: NITROUSN] #959556
03/27/11 12:16 AM
03/27/11 12:16 AM
No I haven't yet, a guy has those new comp ones for $75
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959557
03/27/11 12:20 AM
03/27/11 12:20 AM
N
NITROUSN Offline
NITROUSN  Offline
N
What are you running? I can check my fsm's on the stock specs to see how close they are.
Re: Comp cams 925-16 springs, good choice? [Re: NITROUSN] #959558
03/27/11 12:22 AM
03/27/11 12:22 AM
Actually it's the same Summitt 6401 cam that he is working w on the cam degreeing thread
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959559
03/27/11 12:23 AM
03/27/11 12:23 AM
N
NITROUSN Offline
NITROUSN  Offline
N
what heads?
Re: Comp cams 925-16 springs, good choice? [Re: NITROUSN] #959560
03/27/11 12:25 AM
03/27/11 12:25 AM
452's
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959561
03/27/11 12:29 AM
03/27/11 12:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That cam is not radical..I have specs in the shop on the oem springs to compare. I will try to get them tomorrow
Re: Comp cams 925-16 springs, good choice? [Re: NITROUSN] #959562
03/27/11 12:40 AM
03/27/11 12:40 AM
Thank you bro
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959563
03/27/11 09:46 PM
03/27/11 09:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Factory specs on a 76 b-rb head was this
free length 2.58
closed seat pressure 121-129 @ 1 55/64
open " " 192-208 @ 1 7/16
id 1.01 1.03
installed ht. 1 53/64 to 1 57/64
cam lift was .430
On a 69 b-rb head there were std and hp specs.
free 2.58
closed seat pressure same as above
" " " HP 110 @ 1 55/64
open seat pressure same as above
" " " HP 236 to 256 @ 1 23/64
installed heights same as above.
Cam lift std .425 I and .450 E
HP cam lift .435 I and .458 E
Looking at comps specs I think you should be fine. The 388 open pressure is at 1.200
The one item that bothers me is the inner springs ID at .697. Some guides need to be cut and a special seal used so the spring will not take off the seal. If you have to do that and pay for it buying the right springs may be the best option.
Re: Comp cams 925-16 springs, good choice? [Re: RapidRobert] #959564
03/27/11 09:51 PM
03/27/11 09:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That cam has more lift. I would ask some more on what the valve train survives on spring pressure wise. I have run the mopar 509 but I cant remember what springs we used. I do know it was the mp springs recommended for that cam. My valvetrain survived.
Re: Comp cams 925-16 springs, good choice? [Re: NITROUSN] #959565
03/27/11 09:55 PM
03/27/11 09:55 PM
Nitrousn I owe ya one
