Problem with hazard- and brakelight #958351
03/25/11 08:30 AM
03/25/11 08:30 AM
Pfalz
K
Knillse Offline OP
Knillse  Offline OP
K
Pfalz
Hi,
i just imported a 69 RR to Germany. To get her legal here, one thing, amongst many others, is to invert the existing hazard/brakelight priority. In GER it is mandatory that the hazard lights have to blink even if the brake is hit. Which is vice versa to the U.S. Thought it would be easy to take the hazard switch signal to a relay and the opener disconnects the brake signal. But apparently it isn't. As far as i can see the hazard switch does not use permanent 12V signal to trigger the hazard flasher. Does anybody have an idea how to solve this issue? The car is nearly original, that's why i don't want to change too much.
Thanks in advance
Knillse
Re: Problem with hazard- and brakelight [Re: Knillse] #958352
03/25/11 03:59 PM
03/25/11 03:59 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I got tired of messing with it and bought a turn signal wiring kit from painless.
Re: Problem with hazard- and brakelight [Re: west] #958353
03/25/11 04:07 PM
03/25/11 04:07 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Does it have to be fully automatic? Could you not simply put a second switch in the brake switch line to open it?
Re: Problem with hazard- and brakelight [Re: Knillse] #958354
03/25/11 07:01 PM
03/25/11 07:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Use the pulsed signal to trigger a delay type relay, like is used to keep the dome light powered when the door has been shut... Use the power output of that to trigger your relay that interupts the brake light circuit...
Re: Problem with hazard- and brakelight [Re: 1_WILD_RT] #958355
03/25/11 07:45 PM
03/25/11 07:45 PM
Montana
Y
Y
Montana
I don't believe that will work. I'm guessing the "pulsed signal" you are referring to is the one coming from the 4 way flasher. IT IS HOT AT ALL TIMES, that is the switch is in the column, downstream of the flasher.
The flasher will be attempting to energise the relay at all times.
Re: Problem with hazard- and brakelight [Re: Yancy Derringer] #958356
03/25/11 08:12 PM
03/25/11 08:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your right... More thought needed... It would have to look at output to both front signal lights at the same time as a trigger... If it's acceptable a manual switch to disable the brake lights would be the easiest answer...
Re: Problem with hazard- and brakelight [Re: 1_WILD_RT] #958357
03/26/11 05:38 AM
03/26/11 05:38 AM
Pfalz
K
Knillse Offline OP
Knillse  Offline OP
K
Pfalz
Thanks guys, thought i maybe overlooked an obvious solution. I'll try the "hand made" version
